Need Help Identifying This Connector
I was replacing the valve cover gasket and accidentally pulled a connector loose, as in the wires from the harness. Trying to figure out what exactly it is, so I can get it towed to the shop when I'm done and get it fixed. This video also shows the connector at 14:45. Any help GREATLY APPRECIATED.
Moderador
That's Bank 2 A/F (air fuel) sensor connector.
If you figure out the wiring, super glue the pins to the connector since finding the connector will be a bitztch.
If you find a spare connector you can try to depin the donor connector and install your sensor wires to it, be advised that these take a very fine angled pick tool to depin them
Amazon has the sensor for $66
These are your choices.
Not sure if the backside of the connector is still good.you can try and bend the locking mechanism a bit more to see if it will still lock in place. If you just want a (quick fix )you can get rid of the connectors and maybe just use something like a bullet splice to repair. just an idea
