Sedans on Tein’s
Sedans on Tein’s
Just ordered myself some S tech springs, know it’s a pretty steep drop but can’t seem to find many pictures or threads on them. Can anyone give me a better idea of what to expect, also Did you guys have to do anything extra like a camber kit?
This is mine the previous owner dropped it with tein springs though I want to replace them with coilovers it's to damn low for me gets annoying when you have to use a small jack to lift it up enough for the regular jack to fit under front bumper
backdoorvic (06-02-2021)
Damn that is pretty low now that I see it but it looks nice asf man Fr. I imagine you scrape is it frequently? I’m lowering my daily on teins so just want to know what to expect thanks.
Yeah
got to crawl over speed bumps or else I bottom out the front and the muffler gets scrapped.
Also I have to go at an angle to clear certain dips or driveways.
I can deal with the above but that whole needing a jack for your jack thing is annoying
Also it needs a camber kit the inside of the tires gets eaten up really good.
Had to replace the old set it had because of it.
Beefy tires nice thread on the outside but once you got under the car you could see the steel belts on the inner tire
Yeah
Staggered setup
225 front
245 rear
And I couldn't tell ya the springs were already installed when I bought the car.
But I don't rub at all going through turns and etc
I plan on getting BC coilovers or something similar
225 front
245 rear
I would HATE to drive that around town. It looks like it has no suspension
I bought over $2500 in coilovers and suspension ancillary parts (like Voodoo Front Upper control arms that ran over $700 alone facepalm) all to lower it properly to 26.75 floor to fender. Essentially a 3/4 drop. But it rides amazing and my alignment is in spec for my very expensive Michelin tires. I don't understand how people lower it much further. I still at this height scrape here and there. And when I load up with groceries and kids? Yeah, glad I kept it at the height I did.
Same here... 26 3/4" floor to fender (when no one is in the car ). I think that's the min ride height before it starts being a problem. Anything lower on the G sedan looks broken to me.
I got there with Swift lowering springs in the front, and Tein Basis coilovers in the rear. And before someone asks, because they will, first I had Swift springs all around, but the rear was too low for my taste. So I bought the coilovers and only installed the rears, because the front drop was fine. Then I sold the front coilovers, and called it a day. OEM control arms, but SPC camber & toe kit in the rear.
My fortune auto coilovers are also a Frankenstein. Stock springs were too short and too soft in the rear at the "recommended" rate. So the fronts are running 10k 7" fortune auto springs on the sleeves. The rears? 8" 10k swift springs. Went up from a 7" 8k rear spring that sagged to 25.5 at basically full ride height and even lower with kids.
Thats funny mines the opposite, my front is too low for my taste
I hate bottoming out have to literally crawl speed bumps riding the brake so my front doesn't just slam down.
Hopefully by next month I get coilovers and control arms to keep alignment in check.
It's a waste seeing beautiful tires in the front just to look under the car and see steel belts
Here’s my 12 sport with tein S-tech springs I put in around Father’s Day. Wheels 19x9.5/11, 245/40 and 295/30, all I can explain I grew up building slammed Honda’s and building bagged & body dropped trucks. But I have to remember I’m driving a lowered car, I have never dragged “yet” lol and my drive way gutter is like pulling up to haft dome in Yosemite. I get a lil body flex but nothing bad, it’s rides better then any springs and factory struts set up I’ve ever build or been in. This is vehicle
Number 93, I got a bit of experience in this department. I don’t, or “have not yet” experience any of what people say? I live in Northern California and commute to San Francisco “legendary **** roads” I drive the holy **** outta my v36 and I got nothing but praise to say about them. And at a total price from Amazon at 204.00 and dropped at my door, I’m extremely happy with them! Good luck hoggie
Im on tein street basis coilover ride height is set to 26.5" floor to fender all 4 corners. Im running 245/40r19 front and 265/35r19 rears. I have z1 camber arms and traction rods in the rear and spc toe bolts in the rear. Camber is at -1.6 all the way around toe is at infiniti spec.
The following 2 users liked this post by Eddy Gonzalez:
BloodLine_Prez (07-19-2021),
James Harden (07-30-2021)
