7AT fill help
7AT fill help
So one of the transmission cooler lines connected to the radiator fell off the other day , i was half a block from home and i only noticed because it was slipping pretty bad for that half block , well i fixed the leak but i dont want to drive it , i know i can fill it from underneath the car but is there any way to just add the fluid lost from under the hood ? or is the only possible way to add fluid from underneath? thanks ! fluid was recently changed which is why im not to concerned to change it again, i just need to add what was lost. Any help is appreciated (:
Edit: Vehicle is a 2010 G37 with 7AT
oh wait you have a cooler? you might be able to pump it in through the cooler line, but you still need to get underneath the car to gauge the correct amount of fluid. I don't know how youre going to do that in your case since the thread I referred to only measured what came out and put the same amount back in. I think there was a way to gauge the level on youtube or google search.
https://www.myg37.com/forums/d-i-y-i...rop-clean.html
This is what I referred to when I did mine.
I would just have it towed to the dealership and have them fill it up. Not worth the time and effort. They shouldn't charge more than 150 since a fluid change was 139 for me.
Dopery
03-27-2020 12:31 PM
AbeG37vq
06-25-2019 02:24 AM
UCLAG37
07-11-2017 12:21 AM
