Cruise control will not set
Just had this issue pop up on the freeway. The cruise light comes on when turned on however the toggle switch that sets speed does nothing. Anyone have any clues what this issue is all about?
Edit: did some testing on the way to work and it seems to be an issue with the brake pedal. If I pull up on it I can set the cruise control but it will shut off shortly after I let go. Is there a contact I can clean/spring I can tease out/switch I can replace that alleviates this issue?
There is an "ADSC cancel switch" on the brake pedal arm, under the dash. This is the switch that cancels the cruise control when you tap the brake pedal.
The switch could be loose, needs adjustment or needs to be replaced.
