2010 G37x P0462 error code fuel level sensor
Old 09-20-2020 | 03:37 PM
Spadds76's Avatar
Spadds76
Hi Gang
So my service engine soon light came on when a punter was taking my car for a test drive as I'm selling it, so I need to fix this!
The fuel gauge has been playing up for a while, showing 3/4 to full when it's not. I could live with it and just use the odometer to gauge how much fuel is in the tank.
I scanned the car for engine codes and got P0462 Fuel Level Sensor A low circuit error.
I saw a youtube video of a guy removing both level sensors in his car and cleaning them, so I did that today as all the stores are closed. No change.
I also read that incorrect fuel readings can be from the AC Control module located behind the radio unit.
I did a cluster gauge check, and they are all working fine.
So, my question is what is Sensor A? Is the pump or none pump sensor side?
I have found a used AC Control Module ($700 new, $100 used)
Thanks
LeonAr (11-27-2022)
Old 11-27-2022 | 04:58 AM
LeonAr's Avatar
LeonAr
Solution
Did you ever fix the problem to this?…
Old 11-27-2022 | 10:26 AM
Spadds76's Avatar
Spadds76
Fault repaired
Yes! I did find a solution for this.
The issue was within the AC Control module located behind the radio unit. I think it's behind the top screen and the signals go from the fuel level sensor in the tank, to this module, and then to the fuel gauge.
I was able to source a used replacement module for $50 from a local scrap yard. It was not the correct part number, but identical looking white plastic rectangular unit. As I had the car in pieces and could return the part if it wasn't any good,I took the part home and installed it. Fuel level now worked, but a couple of other nice options on the car had stopped working as this module wasn't the right part number.... So, I went on ebay and found the correct replacement part - shipped up to CAnada.com it was like $70. Installed and boom! All working correctly. I would look at this option first rather than messing with the fuel tank. Removing the pump/level sensors and the old seals, with dirt/road grime etc would only be my recommendation if you check out this control module first. I think the fuel tank is best left alone in my experience. It's pretty easy to get to the control module. Good luck.
abrecos (11-28-2022)
Old 07-19-2023 | 06:18 PM
Tabotime's Avatar
Tabotime
Part number?
Could you send the link or part number?
Old 07-20-2023 | 09:04 AM
ILM-NC G37S's Avatar
ILM-NC G37S
It is best to get the part number off of the module that is installed in your car. This will ensure compatibility and retain all features/ functions specific to your car. See this post as it will show you what the module looks like and where it is.
That said, the Unified Meter/ AC Amplifier part number will be 27760-xxxxx. The last 5-digits will be specific to your car.
Mattimus
31
01-13-2024 09:48 AM
Bryanmilio
General Tech Questions
04-16-2020 12:27 PM
Elitex37x
05-28-2019 09:12 AM
mysticxknight
10-08-2011 06:36 PM
Quick Reply: 2010 G37x P0462 error code fuel level sensor
