Fuel Pump Kill Switch
Hi All,
My car was broken into last night and the theifs were able to ****** my set of spare keys that has a faulty fob, the keys work on the door by entering through the keyhole but the fob will not start the car or lock or unlock the doors from the buttons. I would like to install a kill switch for the fuel pump and was wondering if anyone has done this or know where the fuel pump relay wire is located. Anything would be helpful, the dealer wont be able to reprogram my keys or switch out the locks until 2 weeks from now.
TIA
TIA
Sorry to hear about your situation. Not sure what year your sedan is but the fuel pump fuse is likely in the IPDM which is behind the battery and not very convenient to get to. I'm sure others here will chime in with better ideas ... but it's fairly easy to pop out the rear seat cushion and access the fuel pump. You could simply unplug it or interrupt the circuit at that point with a remote switch...
Envee
03-30-2016 10:28 PM
