Code p0011
Code p0011
I just had the galley gasket and timing chain and water pump replaced also put new spark plugs cars running worse then before help any solution before I take it in to a dealer
About a month an half maybe first it had code p0524 low oil pressure codes went away with the galley gasket fix them it was p0300 random misfire changed the spark plugs 1of them was covered in oil now it's p0011 erased the code cars running fine but that code sent the car into limp mode I'm stick on what to try next
bgoodman
16
10-26-2019 11:46 AM
zzww1251
01-19-2015 11:24 AM
