Need help with staggered setup on my AWD
So I was wondering if I could run 19x9.5 fronts and 19x10.5 for the rears for my wheels. I saw on fitment industries a coupe have the same specs but was running the same tire all around which was 235/35/19 is that ok? I know it’s stretch but can I run staggered wheels if I keep the tire size the same? Thanks for the help
Check this out
https://www.fitmentindustries.com/bl...aggered-on-awd
The key rule to follow is to have a 1% variance between the overall front and rear diameter of your wheel (including the tire)
Tire calculator
Originally Posted by JuicyVQ;[url=tel:4272084
4272084[/url]]So I was wondering if I could run 19x9.5 fronts and 19x10.5 for the rears for my wheels. I saw on fitment industries a coupe have the same specs but was running the same tire all around which was 235/35/19 is that ok? I know it’s stretch but can I run staggered wheels if I keep the tire size the same? Thanks for the help
https://tiresize.com/calculator/ check that link out and I know is the rule of thumb is you got to be within 3% or rolling diameter.
czardini
05-09-2014 07:37 PM
