Just bought a 2012 g37x with 113k
My question is the car had 0 service history (with 113k) so i went ahead and flushed the front and rear diff as well as the transfer case. Im unsure if i should drain and fill the transmission now? Im worried i flush it and then i start having problems with slipping etc. Had an infiniti guy behind a desk tell me that this was a thing of the past. only older transmissions have this problem. Im weary of this so im looking for input! Appreciate it guys.
Dopery (02-16-2020)
Dopery (02-16-2020)
thanks for the info, going to be doing a standard drain and fill once it warms up a bit. I do understand we need to have the trans at a certain temp while doing this service. Ive researched extensively on how to do it. Just havent known if i should lol. Appreciate it guys
yeah, agree with ^^^^ KIMChee, as even with mine at dealer at ~60k miles, they recommended only doing a drain and refill not a flush...it may be an "older" car issue, but why take the risk at this point...do the drain and see how she drives...actually, have someone , open up the fill hole and check the fluid condition and that will give you a good idea on the how really is ...maybe some maintenance was completed just no paper trail etc...good luck
Dopery (02-16-2020)
Dopery (02-16-2020)
kazama5000
09-22-2015 06:06 AM
