G37x sunroof question
New member here , i have a 2012 g37x sedan. I would like to know if sunroof rail and its parts from a g37 coupe are interchangeable with g37x sedan ? Thank you
https://www.infinitipartsdeal.com/pa...350-jk04a.html
Does not specify that it will not work for either one, so I assume it is the same. If anything call the dealership to double check.
