Get some other peoples opinion
Hey guys!
So I am going to get 20" rims for my G, and was wondering if I can get some opinions, and if anybody has recommendations please share with me! This is what I am REALLY looking at.
XO Verona All Matte Black 20x9 20x10.5 Staggered Wheels
I plan on getting air suspension too so if anybody can give me some advice on that, that'd be awesome.
THANKS
THANKS
IMO these look better and about $600 less
Verde V99 Axis Satin Black 20x9 20x10.5 Staggered Wheels
And these have designated 5x114.3 bolt pattern rather than the Universal 5 lug fit, which leaves room for problems (perhaps).
You could run the 9 +38 on 255/35 front 10.5+45 on 285/30 rear for a nice fit.
As far as going air, check Toxic's build thread, superb job he's done
https://www.myg37.com/forums/build-t...a54-sedan.html
Not a big fan of the Veronas, could get the 370Z rims and have the same affect. Also blnwt brings a good point, stick to 5x114.3 bolt pattern to avoid future or present hiccups and constant trips to a shop.
3P airlift seems to be the most popular brand to bag out.
Is your G a coupe or sedan? awd or rwd?
I assume you have a sedan since you posted in the sedan folder, but you didn't mention if you have a S model, if so you MUST confirm brake clearance w/ any wheel you purchase unless there's a member w/ big brakes that's running the EXACT wheels you're wanting. If you have a non-sport model no worries there
Also unless you go w/ a Z wheel or other Nissan/Infiniti OEM wheel that matches our 66.1mm hub ring you need to get adapter rings that will tighten up the hub to wheel fit. Most aftermarket wheels are 73.1mm but need to confirm this w/ the vendor then get the proper rings, also aluminum ones on ebay are about $10-15 and much better for durability than plastic ones.
Here's just one example
(4) Aluminum Hub Centric Rings - 66.1mm - 73.1mm (66.1-73.1) | eBay
