License Plate Frame
Old 05-20-2017 | 02:20 AM
Epiphany's Avatar
Epiphany
I think branded and custom-text plate frames are really tacky, and only one step removed from the embarrassment of dealer-installed plastic frames. They're busy, and often conflict with the design on the license plate itself.
However, I also think the plate needs framing... but it needs to be subtle. So for the last 10 years, I've been using Custom Cruiser plate frames on all my cars. You can find it at any auto parts store, Walmart, Amazon, etc. Very inexpensive, $7 tops.
It has four bolt holes, with the flanges *behind* the plate, so there's a continuous, consistent framing effect. Match it with some black or gun-metal fender washers, and you have a really clean look.
I agree with this, not a fan of any that I've ever seen. Mine is a plain black plastic frame, looks the same as the one you linked but plastic. I cut off the lower 2 bolt holes to make it flush on the bottom though.
Old 05-20-2017 | 02:26 AM
EG Ryan's Avatar
EG Ryan
Old 06-02-2017 | 03:18 PM
brizey's Avatar
brizey
Ohio State frame on the front. Need to get something for the front...car wash is bending it.
Old 06-02-2017 | 05:08 PM
guy from norcal's Avatar
guy from norcal
This is mine.
The only rice this resembles is JERRY RICE #80
Old 06-07-2017 | 10:07 AM
NealP's Avatar
NealP
https://www.amazon.com/Cruiser-Acces...e%2Bframe&th=1
Here's a consideration people should look into before getting a frame: if you're thinking of getting a *covered* frame, with Plexiglas or whatever, not every state allows it. New York doesn't.
I have the same ones but in chrome
Amazon Amazon
Old 06-07-2017 | 10:36 AM
Yeah, I really like these. They provide the necessary rigidity to the plates, and a very clean, unobtrusive trim line. Been using them for years on all my cars.
However, the finish is cheap. Whether chrome or black, you can only get a few years out of them before chrome corrosion or black-paint wear necessitate replacement. Fortunately, they're also really inexpensive.
Old 06-07-2017 | 11:02 AM
JustROLLIN's Avatar
JustROLLIN
Thanks! I have been looking for something basic to replace my dealer frame. Everything I come across is either spendy or just looks ridiculous.
Old 06-07-2017 | 12:25 PM
G10's Avatar
G10
While on this topic, if you have these clips
clips, get ride of it. They're such a PITA to unbolt the plates once the bolts come loose in the plastic housing.
Old 06-07-2017 | 12:39 PM
Originally Posted by G10
While on this topic, if you have these clipshttps://www.pinterest.com/pin/450430400209984304/ clips, get ride of it. They're such a PITA to unbolt the plates once the bolts come loose in the plastic housing.
That's great advice, G10.
One of my rear bolts became frozen in that clip, and the bolt just spun and spun. It was very frustrating. I had to cut the bolt with a loose hacksaw blade held in my fingers. And then replace the busted clip with a more standard type of clip that I picked up at the Nissan dealership. This time around, I put some no-seize on the bolt threads.
It really makes you wonder how dealerships deal with this crap when swapping plate for new or used cars.
Originally Posted by Chekov
To me, it’s best to go with no frame at all.
True to form, that's really bad advice for license plates that hang down without the support of a solid trunk or bumper backing.
Old 06-07-2017 | 06:56 PM
solidsilver's Avatar
solidsilver
Amazon
Me too. Clean and simple - just about perfect.
Old 06-07-2017 | 10:49 PM
G10's Avatar
G10
John -
I went through the same frustration and that's when I learned this lesson.
I didn't think about no-seize on the bolt threads but not a bad idea next time i'll apply some when clean my bumpers.
Old 06-08-2017 | 01:12 AM
ezbme's Avatar
ezbme
Vagina Dentada
