Optima optum red top battery install
i just installed a new red top in my 2010 G (oem still working after 6 years but sluggish in cold mornings).
it's far from a perfect fit. the battery is much smaller than oem - the height is too short and the width is too narrow for the oem tie down. the included spacer fixed the height issue.
i had to bend the hold down to fit properly - i simply bent the tie down in the center to make it fit the more narrow red top. when i tighten the tie down the contact points pulled into position just find. The hold down adjustment is not an issue but the battery is far from plug and play.
The red top is not as long as the oem which is a good thing. the oem was jammed up against a electrical connector.
