Vibration
Emanon (08-21-2016)
Hey guys...unfortunately I'm here again I celebrated early. I was driving today on the highway and when I hit 80 I felt the vibration on the steering wheel again...not too terrible but it's there and seats seem to be shaking too. so, new wheels and new tires balanced and rebalanced multiple times..tires changed, aluminum hubrings installed. What else can I do? I'm taking it to the dealership on Wednesday for them to raise it up and check. What else could it be? Any ideas? Someone had mentioned end links...I'll have a them look into that. What else can I have them check or what else can it be? Thanks guys.
Tough to do over the internet. If you can isolate it to one wheel/tire (assuming one of them is the culprit) then at least you either have the tire or wheel replaced, or maybe get lucky and have it remounted and rebalanced and it will improve. End links even when bad probably won't cause the vibration, but make more of an unstable drive when pushed.
If I were to guess at this point you may have a poor tire and they can look fine but a defect can result in vibration at speed.
And if you've been going round & round w/ the same shop you might take it somewhere new at this point.
Emanon (08-22-2016)
33 years ago, I brought a brand new Pontiac Firebird. Right from the beginning, that car had a persistent vibration at a few different speeds. I must have brought it back to the dealership IDK how many times, chasing down tires, wheels, bearings, whatever. Finally, an outside mechanic suggested I have them test the driveshaft. Damn thing was ever so slightly bent. Don't know how or why, but it was... I watched them measure it.
In the end, they replaced the driveshaft, and problem solved.
Emanon (08-22-2016)
Get out the google, do some research, email your mechanic, call your local Infiniti service department, etc. Good luck.
Emanon (08-22-2016)
