High pitched noise at high engine RPM 2013 G37x
Old 05-27-2016, 11:04 AM
jasec
jasec's Avatar
Hi all,
I have a stock 2013 g37x.
When the car accelerate hard(full throttle), when engine RPM is over 6000 rev/min right before shifting(especially for 2nd and 3rd gears), I can hear high pitched and frequency noise. Unfortunately, I am not able to locate the noise. I have been using premium car and taking good care of my car. Please help diagnose or let me know if you have similar issue. Thank you!
Please visit below link for video.
https://www.youtube.com/watch?v=F6vW...ature=youtu.be
Old 05-27-2016, 11:31 AM
dwb993
dwb993's Avatar
Can't see the video, as it is marked Private.
I noticed a similar noise after I installed my R2C intakes. It seems to have gotten better than it was. I also had to install the rubber molding stuff between the cowl plastics and the windshield, which took out a whole lot more noise I was having.
Because the noise only happens at high RPMs under load, it is much more difficult to diagnose.
Old 05-27-2016, 12:04 PM
Ricio1991
Ricio1991's Avatar
Same here I have the same noise! I'm in for answers! I want to get it diagnosed soon
Old 05-27-2016, 12:05 PM
jasec
jasec's Avatar
Thanks for your reply!
Sorry, I just turned the video privacy to open
Is this the noise you are hearing?
Old 05-27-2016, 12:08 PM
Ricio1991
Ricio1991's Avatar
Look up faint metallic noise on the search button, one member in 2013 said something to do with the wheel well not being properly secured
Old 05-27-2016, 12:12 PM
dwb993
dwb993's Avatar
That sounds a lot like what I have.
Ricio1991, now that you mention that, the noise got better after I did my headlight work, so your theory makes sense!
Old 05-27-2016, 12:34 PM
Ricio1991
Ricio1991's Avatar
I'm definitely going to have to get mine checked and make sure I get all the plugs for my wheel well! I'm glad I seen this post because know i may have a solution to my issue hopefully
Old 05-27-2016, 01:43 PM
jasec
jasec's Avatar
You did your headlight work and reduce the noise?
What exactly did you do? Could you elaborate? thanks.
Old 05-27-2016, 01:46 PM
dwb993
dwb993's Avatar
^I pulled the covers off of the wheel well to get to the lights. It gave me more room to solder and better access overall. Details are in my Build thread in my sig.
I did not put 2+2 together until he mentioned the liners in the wheel well.
Old 05-27-2016, 02:07 PM
jasec
jasec's Avatar
Thank you!
Dealer got my wheel liner(you mean the one covering up the break disk? correct?) fastened and the high pitched noise is still there. This high pitch noise only happens when engine is at high RPM right before shifting, regardless of what road surface condition is.
Old 05-27-2016, 02:11 PM
dwb993
dwb993's Avatar
No...I'm talking about the plastic fender liner in wheel well.
Old 05-27-2016, 05:24 PM
jasec
jasec's Avatar
Ok. I guess the noise I observe is coming from different source than yours. But yeah, glad you found some potential root cause...
Old 05-30-2016, 08:43 AM
Mattlorentzoe
Mattlorentzoe's Avatar
I had same noise with k and n intake. Swapped that for longtube intake. Never heard that noise again.
Old 05-30-2016, 11:59 AM
slartibartfast
slartibartfast's Avatar
The hamsters are complaining about the workload.
Old 06-01-2016, 01:36 PM
jasec
jasec's Avatar
This is what the Infiniti dealership told me:
" I talked to the technician and he said this is the same issue that we looked at with the Infiniti rep. And he said that is normal operation and nothing to do to fix this. I thought you were talking about a different noise. This noise will happen when at that high of RPMs because the engine isn’t designed to maintain that fast of revolutions."
And they have another 2013 G37 that does the same thing.
I guess this noise is normal.
Quick Reply: High pitched noise at high engine RPM 2013 G37x
