Top Speed Exhaust is back. Get it before it goes out of stock again..
Infiniti G35 G37 Sedan 07-14 Top Speed Pro-1 Y-pipe Back Exhaust System (Bevel Edge Tips) is available now.
Infiniti G35 G37 Sedan 07-14 Top Speed Pro-1 Y-pipe Back Exhaust System (Bevel Edge Tips) - Top Speed Pro 1 Performance
m3clubracer (04-22-2016)
Daddy Fat Sacs (04-14-2016)
Hi, I just got this exhaust and went to
Install it today and seem to be running into some trouble. The midpipe is hitting the brace and also the the drivers side muffler pipe is hitting something as well. If someone can let me know of this is normal or if I did something wrong. Thanks
Pipe touching the brace<br/>
Pipe is touching that black part
No idea. I wasn't actually paying attention to this detail when it was getting installed. But the guy who installed he didn't tell me anything like this either. But I will still double check mine. Check your rubber bushings which holds your muffler. There are two of them. You can actually adjust the muffler position because there is room to do it in that bushing.
Add some washers to the bolts between the underbody and the brace to add a little space between it and the exhaust.
You can also slightly loosen the exhaust flanges, try to push up the exhaust and retighten. That may give you a little more room.
For the exhaust hitting the lower control arm mount, is it just one side?
If so, you can try to slightly push it the other direction, trying to make more room.
