#9901
Wrapped up a Oil and filter change and clutch fluid drain and fill, along with EVAP,TXV, and compressor job.
With it hitting upper 90s here, wasn't a great time for this to go but it's been on its last legs for a bit. Got a AC compressor kit off Rockauto and an evaporator. Fairly easy and straightforward install. Cannot get to the drier/accumulator without pulling the radiator so reused OEM. Blowing nice and cold now!
Getting to the evap core took about 30min really easy, take lots of pics of how the actuators mount and hook up.
The TXV hardware is notorious for being seized so that's why I got a new evap. I was able to remove all the bolts but the head cap screws were all rust and needed to be replaced. Couldn't find 35mm locally so had to buy 40mm long bolts and cut em down.
Evaporator core hardware 2x m5x0.80-35mm long (35in-lb) for TXV to core and M6x1-16mm (39in-lb) for lines to core.
The following 2 users liked this post by thescreensavers:
abrecos (07-21-2024),
Krzysztof47 (08-06-2024)
#9905
Today I swapped out my original steering wheel for this wheel wrapped in two-tone leather from Redline Goods. The darker perforated leather on the sides is an exact match for the leather in my shift boot, parking brake boot, and center console lid.
This wheel was a selfless gift from @hexotic . All I had to do was drive up to Canada to pick it up, jk jk, I was up there visiting friends, and swung by hexotic's for the wheel. And I'm very, very appreciative. It looks fantastic.
The following 4 users liked this post by Rochester:
#9907
abrecos (08-04-2024)
#9908
#9913
Originally Posted by rotarymike;[url=tel:4334027
4334027]I was wondering, since those typically use a resistance ladder to cut down on the number of wires going through the clockspring, if they were different than the single-button version. :shrug:
If not, like on my Q60 wheel, the G can't read the two "menu" buttons and, therefore, the buttons do nothing (not that it matters, the heated part makes all the difference) 😁
Being Rochester has the standard ASCD, I'm sure the ICC button will do nothing.
rotarymike (08-06-2024)
#9914
You know, I don't really know. I'll have to check it out. But I do know the left side buttons work. Also, I never use cruise control on the G. Never. Not even to swap tune maps. So if it doesn't work, I'll probably do nothing to fix it.
I didn't notice the ACC control until after the swap was done. My head was so into the swap itself, I had blinders on.
abrecos (08-06-2024)
The following 2 users liked this post by ILM-NC G37S:
Rochester (08-06-2024),
