#8778
Just say no!!!!!
I installed eibach sways front and rear at ~1300 miles. Sold the car around 37K some 8 years later. During that time, never had to retorque the end link or frame bolts for either bar. For that matter didn't have to relube the bushing either. I believe I reused the original hardware on the end links and frame bushings. Did not use a torque wrench, rather torqued them to gudentite using a 1/2" socket.
The loosening is probably a function of the type of roads car is driven on and how much the bars are actually used.
#8779
#8780
#8781
Moderator in Moderation
The whiteline are just bigger versions of the OEM link style ball joint, not the heim joint style the SPL uses. I think the bar ends of the Hotchkis might be to blame - they're VERY thick compared to the stock bar. Next time I see the stock bar floating around in the garage I'll measure it.
I have reached out to Whiteline's tech line btw to see what they say. Maybe *whiteline* should include the metal displacement locking nuts.
The following 2 users liked this post by iCrap:
DanG37 (09-20-2021),
FrogmanKouki (09-28-2021)
#8785
Dash repair pt1...
before:
drilled a tiny hole to prevent the crack from spreading:
I loaded a syringe with some vinyl repair putty
First pass:
Might try another coat to get it more level after this dries. I hope this doesn't keep happening. I don't understand why my car has had no dash issues for all this time (it's an 07) and now all of a sudden its cracking so badly. Need to find some UV coating or something.
before:
First pass:
#8786
Moderador
I gave up trying to question life and it's existence on these dash's. You did it correctly though, drilling a hole to prevent the crack from continuing.
It might take 3 tries to get it all level, on your last try leave some excess and the tape so you can glide a blade and cut that excess off.
Welcome to the crack club, vicious cycle, it'll ruin your life, might need rehab after
#8787
So take 3 for alignment to fix the twitchy car problem - this time at the Infiniti dealer.
0 for 3.
This time they tinkered with the car for 3.5 hours, did two test drives (FI exhaust means no sneaking the car out) and then... nothing. Told me they couldn't do anything because the car is too light for the suspension that's on there, and it's just going to bounce around. Thing is, this happened with the OEM springs, shocks, and swaybars too.
Hotchkis bars, Nismo Z springs, and Koni shocks... not a rare and exotic or incredibly hardcore combo. The car shouldn't twitch like it has a palsy when going down a straight (but not perfectly smooth) road.
I've reached out to Z1 to see if they can fit me in early - if so, I'll be headed down in the early AM Friday to get the car to them. Hopefully someone who actually works on these cars while modified can figure out something... my racing buddy is theorizing that maybe the rear bearings are just enough shot to move when loaded. I can't find any wiggle or play in either end of the car, so...
At least they washed it for me, and didn't charge me for not doing anything. To be fair, the service writer and tech were both up front and honest and if I needed something like the AC recharged or glass replaced I'd happily take it to them. But anything modded is aparently voodoo... which is funny since I saw several modded Q60s there in the shop. Dunno, but I'm getting worn out trying to make my luxury sports car behave like one.
0 for 3.
#8789
Or maybe that was just me and no one really cared, LOL.
#8790
Moderador
0 for 3.
0 for 3.
I do suspect it's bushing related, I noticed the rear strut bushing on G/Z chassis sees some weird angles upon load and unloads which with it being tightened off load can twist and untwist upon rebound/bound and if you have some weak toe bushings can move your toe as it's bouncing which is why you can never really tell being that tire wear is fine, it's only upon loads/bumps/lane switching.
That's my theory.
