Old 06-21-2021, 11:49 AM
  #8701
STownSaint
STownSaint's Avatar
Welcome the skepticism, the few mods I have done are usually not too widely regarded. And thanks for the heads up, I’m about 60/40 on doing it myself.
How was swapping out the shift boot? That looks like it could be a pain too, with all those little clips. Did you remove the entire piece of the console (up to the ash tray), or just unscrew the shifter surround part?
Here’s a crude mock-up, black all season mats + black buttons and gauge cluster convinced me the contrast might tie-ie, but I could be wrong):
Old 06-21-2021, 12:11 PM
  #8702
RMB5190
RMB5190's Avatar
Next project is about to commence. OEM 350Z shift **** + Redline shift boot (black suede). Exciting “upgrade” for me, because: my OEM shift **** is worn out and always looked odd to me, I strongly prefer the shift pattern to be on the **** vs on the shifter surround (will need to figure out a good way to cover that one up), I think the black **** and boot will be a nice contrast to the stone interior, and the OEM leather (vinyl?) boot is very noisy to me. So pretty pumped, just trying to figure out if it’s worth it to try myself or Go to the pros.
Am I crazy for attempting the install myself? Several good YouTube videos out there, so the steps seem straightforward enough. And I have a strap wrench, vice grips (to hold the linkage to the transmission in pace), and towels needed to pull off the job. Just never tried anything like this before...
I know a dude in MD who would be willing to help
STownSaint (06-21-2021)
Old 06-21-2021, 12:33 PM
  #8703
Received 4,727 Likes on 3,532 Posts
Back in 2016, my shift boot project started here: https://www.myg37.com/forums/build-t...ml#post3981141
And ended up like this:
Old 06-21-2021, 01:43 PM
  #8704
STownSaint
STownSaint's Avatar
In that case, will be texting you shortly!
Old 06-21-2021, 03:09 PM
  #8705
RMB5190
RMB5190's Avatar
Sounds good! We can figure out a date for July that works.
STownSaint (06-22-2021)
Old 06-22-2021, 09:55 AM
  #8706
rotarymike
Moderator in Moderation
rotarymike's Avatar
Removing the shift boot surround is easy-peasy. The shift boot itself will take some effort regarding the plastic frame, but work slowly and carefully (and use a sharp fresh xacto blade to cut off the mushroomed plastic) and it will be easy. Mine is all taken apart; I should be able to put up some pics this evening.
Old 06-22-2021, 10:39 AM
  #8707
Yeah, I forgot about that. I decidedly did not like doing that, but in the end it didn't matter. The stubs were enough to hold things in place.
Old 06-22-2021, 11:09 AM
  #8708
rotarymike
rotarymike's Avatar
You can usually press on the little inward-star lock washers to hold things in place, or re-melt the plastic with a heated spoon or soldering iron.
Personally, I usually use leather cement or black RTV. I've seen folks use hotglue as well, but I don't trust that stuff with any sort of structural job.
Old 06-22-2021, 01:01 PM
  #8709
STownSaint
STownSaint's Avatar
So the plastic stubs align with the holes along the outer edge of the shift boot, then there are like 4 tabs which snap the shifter surround back in place and sandwich the material of the shift boot, right?
You guys are saying that’s not enough to keep the shift boot in place (attached at the bottom)? Adhesive is needed too?
Grateful for any photos, Mike, if you remember to snap a few while your shifter is all apart.
Old 06-22-2021, 01:46 PM
  #8710
Mike is saying that. I said exactly the opposite thing.
Old 06-22-2021, 01:57 PM
  #8711
rotarymike
rotarymike's Avatar
I'm not saying it is NEEDED, but what *I* do. My auto maintenance mentality comes from USAF aircraft maintenance, and I freely admit that I over-engineer solutions.
Old 06-22-2021, 08:09 PM
  #8712
STownSaint
STownSaint's Avatar
Ah, 10-4
Old 06-28-2021, 12:27 PM
  #8713
rotarymike
rotarymike's Avatar
Finally got into the garage. Shift boot surround pics: (pardon the huge mess)
(funny thing - I can't, at the moment, find my new leather shift boot)
STownSaint (06-30-2021)
Old 06-30-2021, 08:01 AM
  #8714
ChefMatt
ChefMatt's Avatar
Paddle Shifters Install Done!
Installed shifters this morning, they look great behind the flat bottom wheel.
The following 2 users liked this post by ChefMatt:
2GoRNot2G (07-01-2021), BoomerSpeed01 (07-07-2021)
Old 06-30-2021, 08:03 AM
  #8715
hexotic
DIY Cheapskate/Mod
hexotic's Avatar
Too bad you're not around me, I'd give you a red stitched version of that shift **** to match the steering wheel.
Quick Reply: What did you do to your Sedan today?
