#8116
I have the silver TBW undertray. I also have the Fumoto drain valve which I directed to pour out so it flows out perfectly through the open tray. Best money I have spent on oil related products. Hardly get my hands oily unless I juggle the oil filter.
https://www.fumotooildrainvalve.com/...MaAud5EALw_wcB
There's the F133 (no nipple), F133S (short nipple) and the F133N (long nipple).
And now I'm just going to say "nipple" again, LOL.
#8117
@ngolbuff , which of the three did you get? If I do this, I'm thinking I'd like to get the long-nipple version and a length of hose, but IDK if the long nipple version clears the TBW undertray. Or maybe play it safe and get the short nipple, then get one of these for the wife's Subaru. I just changed her oil yesterday, and there's ample room for the long nipple. The plastic would be nice too, because for some reason the Subby drains oil like a freaking fire hose.
https://www.amazon.com/Fumoto-F133S-...0546854&sr=8-4
NIPPLE. #FreeTheNips
Rochester (09-19-2020)
FreightTrain (09-20-2020)
#8119
Bought the F133S. Thanks guys!
#8120
Looking for suggestions (7AT). Had a rough idle at stops. I cleaned my throttle bodies today. Just pulled my intakes out, put the car in “On” and in drive with a brick holding the accelerator pedal down to open the butterfly valves so I wouldn’t need to touch them. Cleaned a ton of build up out. Everything reassembled car took way to long to turn over, but eventually did on the first attempted.
Drove fine, but I had a weird intermittent deeper buzz when I was stopped at a stoplight. Pulled off to check and everything seemed fine. I know it had to do with the throttle bodies because the hum was similar to my car in D with the valves open when I cleaned them. Did the pedal dances and the car was performing well above expectations afterwards in my local group.
An hour later, I’m driving home and my car experiences it’s first limp mode, on the ****in highway with construction so no pull-off lane... scared the hell out of me. Cruised through it at 28mph and ~2500 rpm and eventually was able to pull off. Shut off for 5mins, started and drove home.
Driving home there were times where the trans felt like it was about to reengage limp mode, but never did once I put a little pedal into it. If I stayed around the same mph and rpm, it would start to studder after a few mins, similar to how limp mode feels just less extreme and only until I reengauged with the pedal. If I engaged to accelerator, it would stop. 98% of the 25min drive home was normal though. Floored it through some areas (to replicate when it first occurred) that had places to pull off. No issues. No CEL ever.
kinda pisses me off lol. When I first bought the car I man-handled those throttle bodies to get them clean with no regard to the butterflys. No issues. 40k later, I try to do it safely and **** hits the fan.
My plan is to disconnect the battery, reconnect after an hour or so, then pedal dances. Basic but everything points to an ecu issue. Hoses and such all looked good and were properly secured. Butterfly’s didn’t have any loose play. Anything else I should check as I’m doing those?
no error codes and every shop was closed when it happened so no diag. I’ll do it properly tomorrow or Monday, but just looking for additional info to check.
I’ve never experienced limp mode and with an infant and one on the way, I’m not trying to put my family in danger like that. Highway limp mode was scarier than when my previous car had the accelerator pedal stuck 90% in pulling out of my driveway. I turned the key to stop that after everything else failed... That won’t work on a push to start...
Kpmikey808 (09-22-2020)
#8121
It would be very hard for me to single out the redline fluid. The car most likely had 45k miles on the original fluid so any change would be significant. Not to mention the CMAK & clutch fluid.
#8122
DIY Cheapskate/Mod
#8123
So I got it all figured today. My garage light went out yesterday so I didn’t bother looking over things last night. Popped the hood this morning to disconnect my battery and saw one of my intakes was completely disconnected from the coupler... whoops. Not sure how I didn’t see it last night. Oh well, easy fix.
hexotic (09-21-2020)
FreightTrain (09-25-2020)
#8125
Moderador
You could quickly open TORQUE or OBD fusion and find out the issue.
#8126
My OBD scanner never left my Volvo. It was nice having it in there when it threw a code but when it's throwing codes every day it's a sign.
So...not sure if I just suck at painting calipers but I've tried three separate times to paint my calipers and they turn out looking like trash every time. I sand them down, clean them, primer then paint and yet, it seems like the primer won't adhere to the metal. It comes off very easily and the paint and primer just peel off. Any ideas, tips....someone close by who would like to help ?
I've had this BBK for quite a while and my wife has notified me that she's tired of seeing the rotors and pads still sitting in the office....
#8129
Not sure what the issue is.
#8130
After the first failed attempt, I went with VHT high heat primer and paint. It's almost like the primer and paint wont harden; despite letting it sit in the summer sun for over 5-6 Hrs to cure. It's been months since I painted them (and many more hot days sitting in the garage, 90+) and I can go out there right now and scratch it right off with my nail. There's even spots where the paint is visibly still wet.
