#7426
Harness extensions for long-tube headers? I didn't even know that was a thing.
So you're not expecting any O2 out-of-range CEL with this setup? I mean, there's no catalyst in this system, right?
I can only image your State doesn't do visual inspections on the exhaust. NY does.
PNW_IPL (12-20-2019)
#7427
for the out of range issue the long tube has a built in anti filter.
I'm in wa state so no inspections ever. No emissions test after 2019.
#7430
#7431
Moderator in Moderation
Got the Kumhos mounted and put the front Coupe Sport wheels on to replace the spare and other ailing tire. Was going to try to get at least one coat of plastidip on the rears but it looks like it will be wet over the whole week.
On a similar note, found my old Air Force goretex top and bottom so I will be putting her on stands and starting the exhaust and diff mount tonight or tomorrow morning.
Question: 2013 Sedan, I need to get Infinity to use a Consult computer to learn the new TPMS sensors, correct? Not a Nissan dealer, not an aftermarket shop?
#7432
#7434
Thought I'd tackle installing some few things since I had more than one day off in a row, and my in-laws were in town so I'd have A. someone to distract my wife and B. second car available with mine up on jacks.
... yeah, that didn't work out so well on time. I still maintain that I beat the car rather than it beating me, but I took my licks.
Got the car up on jack stands and took the wheels off to get better access to the rear of the car, and check the tires since I had a front blow last week. Uh Oh - looks like I won't have time to paint the new rears before they need to go on the car.
Started with pulling the stock exhaust in order to install the FI HFC and catback. Demon bolts took hours but I finally broke them after breaking some tools. Something no one mentions in cat replacement threads is that one of the easier bolts points forwards and there's really no room to get a wrench on it. I could have made something if I still had acetylene and a TIG, but we finally figured out that going through the wheel well over the lower control arm got you at least a few clicks on the ratchet per swing.
Stock exhaust wasn't in too bad shape. Tiny secondary piping though.
So cats out, exhaust off, new cats on, S pipes on, X pipe on, waiting to tackle the differential mounts on day two.
Day two - spent an hour disconnecting stuff to get the diff out. Diff out on jack, easy peasy (used a cargo strap to make sure it didn't roll off). Popped out front diff mounts with socket and LFH, refilled with Redline diff goo, and started working on the rear bushing which was bad since before I bought the car. Fast forward to 6 hours later - finally got that m-f'er out.
Mine had 2 metal shells to cut through - killed a bunch of bimetallic sawzall blades until I said F it and grabbed a rescue blade I had laying around.Glad I didn't cut the subframe in half with that thing.
Finally got the whitelines in, diff reinstalled and spinny things bolted up. In the process took a driveshaft to the face hard enough to look like I got in a fight, not to mention all the busted knuckles. The other lawyers in the office are keeping their distance from me today like I just joined Fight Club or something. LOL.
Ubered to work, will bus home. This weekend is reinstall rear swaybar, heat shields, finish exhaust, finish short shifter install, install coupe wheels on all 4 corners.
Been a good few days
#7437
#7438
Something like this:
I think mine are Milwaukee brand, "The Torch" or something like that. 12" metalcutting blade. I used one to cut a junk car in half to make a trailer from the rear end.Took 10 minutes to cut the entire car in half. It won't go in the diff bushing unless you've already cut the rubber part out.
I might suggest cutting out the rubber middle and packing the hole with dry ice. Or try to make a puller tool that seats on the outer rim of the bushing.
Rest of the diff mount went pretty smoothly, just a lot of stuff to take off and put back on the car. I twisted up my diff vent tube pretty badly but it still flows air and hooks to the hose so... :shrug:
Also - a lift will make everything much easier. My upper body is wiped after 6 hours hammering above my head laying on my back with a 10 pound sledge and cold chisel. That's why I dropped the driveshaft onto myself - arm finally gave out.
2GoRNot2G (12-30-2019)
