#7096
Moderator in Moderation
Adams was just the first google result... I was looking at their custom 2-piece rotor service, not the premades that are just drilled/slotted. I know in the racing world there are a bunch of manufacturers that will custom-build 2-piece setups and stock the friction disk to make replacement relatively easy.
I've had disappointing results with Project Mu - they were not any better than Mazda pads on RX7 turbos. No experience with Endless. Ferodo was popular with some heavier car chassis when I was racing. But the dominant brands I saw at the track were Hawk and Porterfield. Toward the end of my time in NC (2008 or so) I started seeing various EBC compounds too. Have EBC Green on our CX5 as there aren't a lot of performance pad alternatives for a transportation appliance.
I've run hawks on 1st, 2nd, and 3rd gen RX7s street and track cars, an RX8, an RX2 race car, my Jeep Cherokee, our tow Suburban, and my Mazda3. My only problem was when running Blues on the street with a 1st gen RX7 - they wore almost completely through the rotors so you could see the shadow of the vanes inside. My fault for running a hot pad on the street.
The HP+ I had on the RX8 were breathtaking. As in, the brakes squealed because you were decelerating hard enough to squeeze the air out of your torso and couldn't make any noises yourself.
#7097
I ran HPS like 15 year ago. I just think there are better, albeit more expensive, pad options
#7099
I've heard great things about Specialty Z and Seb but I feel as though if you can dyno tune then that's the way to go. They can dial you in right then and there. Just wondering why you'd go with a remote tune when you probably have a good amount of tuners in your back yard.
RMB5190 (07-31-2019)
#7100
No test pipes... resonated high flow cats (RHFC) from Fast Intentions.
I'm at 43k miles on my original brakes (Akebono BBK), and I'm starting to feel it, so the brake upgrade is happening first. And since I'm planning on the 2-piece rotors from Z1, that isn't going to be cheap and gets in front of the tune on the annual budget.
Rochester (08-01-2019)
#7102
Your car and your photo? That looks exactly right, particularly with the gold Akebono calipers. Stock, not-stock. Love it.
#7104
You guys are starting to sway me towards gold calipers vs red for my black sedan with black coupe wheels.
I've talked to the G2 tech support folks, you can mix colors but they of course don't guarantee results. You just have to mix two complete cans of the stuff and the reducer to make sure it catalyzes properly. IIRC, you need two cans of the stuff to do our large calipers anyway.
So... red-gold? red-black?
#7106
https://www.myg37.com/forums/picture...ml#post3924998
#7108
Technically last night, but I couldn't get pictures till today. Attempted the window trim DIY. It came out ok, it was my first time using vinyl. Some flaws but I dont think the average person would notice in my opinion
#7109
I put in the dual catch can g37 kit from ADD-W1 on. It seems solidly built and already has a 1/2 ounce of gunk in them after a couple hundred miles.
I know we don’t “need” catch cans on our NA engines due to the port injection. I just don’t like the idea of sucking the crankcase gases back into the engine to be burned off.
I also took the car to the Infiniti dealership and they fixed my leaking transfer case rear seal as a good will gesture. The car has low mileage but, technically is out of the 6 year power train warranty. Saved me a lot of hassle and sweat to do it myself so thank you Infiniti!
