#5986
Next year will begin some majors changes. Due to an accident the halo modded headlights were replaced with stock, I plan on doing my own. I have the cf fenders from the fb group buy, and I plan on making the fog light housings brake ducts also using the Z1 370Z kit they sell. Also would like the two piece rotors but we'll see. Battery relocation is probably next.
#5989
Did some preventative maintenance: replaced the serpentine belt (with Continental Elite) and transmission fluid D&F (with Nissan Matic S) at 76k. My dad has almost 450k miles on a 2001 Acura TL-type S and i'd like to beat that......or at least try
Also, swapped out the Toyo tires for the Conti DWS06 and it drives so much better. And looks better as well.
#5990
https://youtu.be/uiHJ89ugrL8
Installed these over the weekend. Build quality feels identical to the OEM ones. Perfect timing because my OEM headlights were the only thing on my car that made it look dated from the oxidation and the defects of customizing them years ago. I rewired them to where they're on all the time and not just when I turn the parking/side marker lights on. So far, zero complaints. Love the overall look and especially the strobe. I also detached the H7 turn signal bulb that's located on the top.
Haven't had much time driving at night, but output so far looks good. My output was off on my OEM headlights from doing the clear lens swap and not putting in the 1mm spacer or w/e in to sharpen the light so I'm sure at least for me...these are an all-around upgrade.
#5991
You should have seen it before, it hadn't been used outside of 2 dead cars for nearly 12 years. I had to clean it out and push my old supra shell out to put the new G in there. The cement is broken in some key spots but over all it's very usable. I really need to jack the car up higher so I can start working on the exhaust.
#5993
Moderator in Moderation
Yesterday I went to the pick-n-pull (in the rain no less) to get a VQ35HR lower intake and fuel rail off an M35. Sadly, 1 year off - it had the older DE engine.
On the other hand, grabbed a back-up camera from a Ford Focus for $5 and finally found the long j-bolt to secure my battery, so not a total waste of out-of-work time.
#5994
DIY Cheapskate/Mod
#5995
Today I swapped shift ***** for winter.
#5996
Not all done today but since I haven't posted in a longtime... thanks to all contribution of this forum users, I was able to set my car just the way I wanted. SO A BIG G37 DRIVER THANKS!.
OEM & roof spoilers on....
New R1 Concepts brake rotor and pads on, had them on my old 03 G35 and they were and still good for daily driving.
Lowered with swift springs, low enough for me.
Zenclosure custom 12" box loaded with RE sub., Polk audio 6.5 with 1" tweeters in all upper-doors...all integrated with an AudioControl LC7I LOC and a Rockville 5 channel amp.
FI RHFC and 18" CBE pending order, the wait is on...
#5997
i know i’m late but i’m waiting on pictures to see the silver w red calipers!
staskz (11-14-2018)
#5999
