Old 05-14-2018, 07:56 PM
  #5206
Lego_Maniac
Lego_Maniac's Avatar
I’m surprised they couldn’t get front camber closer to spec. It’s usually the rear that’s the issue
Old 05-14-2018, 09:05 PM
  #5207
hexotic
DIY Cheapskate/Mod
hexotic's Avatar
I’m surprised they couldn’t get front camber closer to spec. It’s usually the rear that’s the iws
Nah, Im the same way, -2.2 on both fronts, and dialed the rear in from -2.8 to -1.9. My front is still -2.2 and its absolutely fine. In fact, because of the caster, much grippier during turns. My Yokohama Advan Sports from last year were worn almost completely evenly. 1mm difference between the inside and outside tread after 40k km. I would try to dial the rear in though. Car wasnt putting down 100% power to the ground because of the camber at full throttle (note this is at almost -3° though). Barely noticeable, but overtime costs you in gas and tires.
Old 05-15-2018, 09:03 AM
  #5208
Baadnewsburr
Baadnewsburr's Avatar
Originally Posted by SheLLz
So I had the alignment done at another Firestone that supposedly had the specific lift needed for lowered cars. A mechanic from one of the Firestones directed me to this specific one to have it done and I guess it worked out. I still agree with Rochester though on the profiling.
I still don;t get this ....I think you were definitely profiled...any alignment shop that I've ever been "too low" for has just put a couple of pieces of wood in font of the ramps to get me up and we were good to go...
Old 05-18-2018, 12:08 AM
  #5209
Saltman
Saltman's Avatar
My super duper project to prepare for import alliance Alabama in July.
1) Action camera mount from pvc piping on headrest.
2) Custom vinyl wrap highlights
3) Airlift V2 install
Got a few more things to do and finish but that install was a beast. I'll never be doing it myself again that's for sure.
Old 05-18-2018, 12:17 AM
  #5210
mvx
mvx's Avatar
Nice! How do you like the air lift?
Old 05-18-2018, 06:23 AM
  #5211
Received 4,647 Likes on 3,477 Posts
Originally Posted by Saltman
I think I like that Partridge Family wrap over the glove box. It works in a creative sort of way, and the colors are in keeping with your car. Pretty cool stuff, OP. But then you went and put the same wrap on the shifter trim, and that ruins the look. IMO, the shifter trim would look better in the same wrap as your center console.
Not to focus on the least expensive project, but that's what I'm thinking off the top of my head. Either way, damn impressive hobby, Saltman.
Old 05-18-2018, 08:31 AM
  #5212
DollHouz
Young, Dumb and Stung
DollHouz's Avatar
Was able to get this installed yesterday very fun install was able to get in without removing bumper which was nice. Might grab 2 filters and make it a dual but this shall do for now.
Old 05-18-2018, 09:12 AM
  #5213
Saltman
Saltman's Avatar
Hated the install. Rides nice. Still need to do some adjusting though.
I see your point. I had the shifter trim in the same wrap as console and was testing little highlighted areas. Didn't want to overdue it. I may swap it back and just leave the glove box. We'll see....
Old 05-18-2018, 10:11 AM
  #5214
Scottvdken
Scottvdken's Avatar
What CAI is this that you were able to install without removing the bumper?
Old 05-18-2018, 10:15 AM
  #5215
DollHouz
DollHouz's Avatar
The takeda attack but i will say it wasn't easy my hands are scraped up a bit but well worth it in my opinion.
Old 05-18-2018, 10:30 AM
  #5216
hexotic
DIY Cheapskate/Mod
hexotic's Avatar
Yeah, the Takeda can be installed just by removing the plastic cover thats over the radiator. There is no cutting involved. I've helped my buddy install his, and Ill say wear long sleeves and use work gloves or youll get scratched to hell.
Old 05-18-2018, 10:40 AM
  #5217
Lego_Maniac
I still cut the support beam, otherwise the rubber couplings were all crushed and distorted
Old 05-18-2018, 10:44 AM
  #5218
hexotic
DIY Cheapskate/Mod
hexotic's Avatar
Did you unbolt those plastic ducts from the OEM intake? Had 0 issues with the couplers crumpling once we took those off. Although thinking back, I guess it did become an oval shape instead of a circle shape.
Old 05-18-2018, 10:50 AM
  #5219
Lego_Maniac
Yes, I removed them. Seemed like there would be a restriction. IDK, it was easy enough to dremel off the support with a cutting wheel, then clean up with a grinding stone, file and sand paper.
Although saying that sounds more complicated than it was
Old 05-18-2018, 11:10 AM
  #5220
Did you enlarge the inlets, or just shove the rubber elbows in there? And did you get the splash shield?
I've never removed my front bumper, but was under the impression that to do a solid job with the Takeda, it helps to remove the bumper. (And that with the Stillen Gen3, you have to remove it.) I've always though that someday I would transition from the R2C to the Takeda, but the whole bumper thing keeps walking me back from the project.
r2dmax (05-18-2018)
Quick Reply: What did you do to your Sedan today?
