#3317
Adjusted my parking brake and checked the status of the brake pads all around in preparation for state inspection. Also, since I just had new tires put on, it was a good opportunity to properly torque the lug nuts since the wrench monkeys at the tire shop can't be trusted to torque them to anything less than however many hundred foot pounds their impact wrench does.
#3318
Installed a Torque Solution short throw shifter along with a Raceseng Sphereology weighted shift **** today.
I really like the new feel but it now has a buzzing in the shifter that I am not happy with. In cruise its quiet but as I go thru the gears it's annoying.
I'll see how it goes as I get used to it.
I'm also going to do something with the trim ring to get rid of the gear pattern as the **** has it now.
Tripleblack_ (07-19-2017)
Tripleblack_ (07-23-2017)
#3326
Duckfeet rule!!!!!
blnewt (07-20-2017)
#3328
Installed HPS post-MAF intake tubes and aFe Pro 5R drop in filters in 105 deg Arizona summer heat.
#3330
It's funny because this forum has made me a skeptic of any engine performance bolt-ons short of high-flow cats/test-pipes and ECU tunes - which are almost unanimously praised for actually making a difference. I didn't expect to be impressed with this upgrade, but I'll tell you it smoothed out the upshifts under partial throttle, and when I buried it, that VQ37 engine winding up sounded noticeably better (ITBs would be like euphoria with this engine) and the car charged a bit harder. I feel like this was a worthwhile upgrade for the money spent and the time invested to install it. My next mod is a pair of Fast Intentions RHFCs, which are slated to be here early- to mid-Sept. Then I plan to hit the drag strip and hopefully between the weight savings, mild intake upgrade, and RHFCs, I'll lay down some better times.
