Old 03-30-2017, 09:12 AM
  #2431
Lego_Maniac
Lego_Maniac's Avatar
I have the Tekeda's, dropping the bumper is quick but not a necessity with the elbow tubes. Word of advise though, you may want to dremel out a small portion of the rad support so that the elbows arent pinched.
Youll see what I mean once your in there, but just take off the grille rad cover and you'll have no issues at all.
Thanks for the advice. I might give it a shot with the bumper on.
Did you use a cutting disk or grinder attachment?
Old 03-30-2017, 09:21 AM
  #2432
Received 4,727 Likes on 3,532 Posts
Originally Posted by VIVID
suggestions for the strap...
Sand off the corrosion and get a matching race-spec Ti bolt, M6-15mm.
Like I'm one to talk... I've had a broken bolt from the relay box bracket that's been stuck in the fender and mocking me for two years now.
Old 03-30-2017, 09:34 AM
  #2433
VIVID
Pyroclastic Flow
VIVID's Avatar
What about this in the interim?
Sean
Old 03-30-2017, 09:48 AM
  #2434
Sweet!
Now don't let anyone tell you to start polishing and waxing the accessible painted surfaces in the engine bay, because that would be crazy... right? LOL
VIVID (03-30-2017)
Old 03-30-2017, 10:24 AM
  #2435
Daddy Fat Sacs
Daddy Fat Sacs's Avatar
Yea should have no probs with the bumper on, I just used a flapwheel sander as it was very minimal that I needed to sand off. But you can use the cutting disck np, just be sure to smooth out the edge once done so that it doesnt tear in the hose.
Amazon Amazon
Old 03-30-2017, 11:08 AM
  #2436
VIVID
Pyroclastic Flow
VIVID's Avatar
Update - don't do this!!
Sean
Quick note:
Those fasteners pictured DO NOT create a reliable ground. I'm back to OEM for the time being. Live and learn...
Sean
The following 2 users liked this post by VIVID:
Nico-derm (03-30-2017), Rochester (03-30-2017)
Old 03-30-2017, 11:14 AM
  #2437
Baadnewsburr
Baadnewsburr's Avatar
Quick note:
Sean
lol, I was just about to post asking how the aluminium washers (not sure what the bolts are made of) affect the ground. but they do look good...I wonder if you could tuck a stainless steel washer behind them with the same circumference to get the ground and maintain the pretty.
Old 03-30-2017, 11:25 AM
  #2438
4doorfury
4doorfury's Avatar
The easy fix to that is polishing the paint underneath the connection to bare metal then use dielectric grease between the cable and body of the vehicle. I have done that many times in the past and years went by without any corrosion. I live in the south though which may have something to do with it.
Old 03-30-2017, 05:36 PM
  #2439
VIVID
Pyroclastic Flow
VIVID's Avatar
Thanks guys. I'm gonna leave it where it lays for now. I had to clear two SES errors from that little stunt. lol
Sean
Old 03-30-2017, 05:40 PM
  #2440
VIVID
Pyroclastic Flow
VIVID's Avatar
Oh but I did finally switch back to my warm weather wheels/tires.
And like any good wheel *****, I'm gonna ditch my coupe 19's finished in sunken treasure for something new...not sure what yet though.
Goodbye it was a nice ten months...lol:
Sean
Old 03-30-2017, 06:41 PM
  #2441
hexotic
DIY Cheapskate/Mod
hexotic's Avatar
Sean
My mechanic buddy drilled out a bunch of pennies and put it under the aluminum washers lol.
VIVID (03-30-2017)
Old 03-30-2017, 09:19 PM
  #2442
Nico-derm
Nico-derm's Avatar
Must have been american pennies, seeing as we no longer use them, and the most recent versions were not made of copper anyways.... if he did have some old ones lying around this would be the only practical use for a Canadian, props!
Old 03-30-2017, 09:49 PM
  #2443
hexotic
DIY Cheapskate/Mod
hexotic's Avatar
Originally Posted by Nico-derm
Must have been american pennies, seeing as we no longer them, and the most recent versions were not made of copper anyways.... if he did have some old ones lying around this would be the only practical use for a Canadian, props!
Canadian, but old ones. He has a bag of old pennies just for this kind of stuff, it's kind of funny. My neg battery terminal is a bit damaged and loose, right now 'fixed' with a penny haha.
Old 03-31-2017, 07:06 AM
  #2444
VIVID
Pyroclastic Flow
VIVID's Avatar
I know this is off topic, but the ingenuity of car people is truly fascinating . BTW, I don't think US pennies are all copper anymore either...IIRC they're zinc with a copper skin.
Sean
Old 03-31-2017, 09:32 AM
  #2445
Baadnewsburr
My negative battery terminal is stretched too. to the point that its come off after driving over really bad roads a few times... I got these lead shims for 3 about dollars the other day, but I've been contemplating just replacing the cable ...I wonder if this is a common issue with these cars.
Quick Reply: What did you do to your Sedan today?
