The Sedan Exhaust Thread
Old 01-10-2023 | 11:07 AM
  #1876
backman_66's Avatar
backman_66
I won't be the guinea pig for that one! I've already tried the twin loops
Rochester (01-10-2023)
Old 01-10-2023 | 11:08 AM
  #1877
Drone = the exhaust hitting a resonant frequency for the chassis at some point in the driving envelope. I'd hope the major players tune those freqs out...
Hmm. A resonant frequency for the chassis? In that context, frame and drivetrain bracing modifications impacts the situation.
At highway speeds, it's more about the volume from my FI exhaust than it is about any humming noise because of a sweet spot of resonance frequency. Also, at highway speeds my RPM is a little higher than normal because of the short rear gears, so there's that.
Old 01-10-2023 | 12:10 PM
  #1878
rotarymike's Avatar
rotarymike
Moderator in Moderation
Same here. No drone - just perhaps excess noise.
edited to add: When I bought my FI, it was after looking at systems from a performance and an engineering perspective. FI seemed to do the best re: engineering next to Meistershaft, which IIRC was almost $10K for the whole exhaust.
Old 02-26-2023 | 06:30 PM
  #1879
jroptop's Avatar
jroptop
Anyone try this set up with the stock cats and resonators? I cant find any sound clips..........
https://topspeedauto.com/infiniti-g3...vel-edge-tips/
Old 02-26-2023 | 08:58 PM
  #1880
thescreensavers's Avatar
thescreensavers
Basically a muffler delete, seems a bit expensive just for tips.
Old 02-27-2023 | 05:56 AM
  #1881
jroptop's Avatar
jroptop
Yes a bit pricey but I can source the work out to a local shop for less…I was just curious as to how much louder it would be as I dont want loud
Old 02-27-2023 | 07:58 AM
  #1882
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
This old video of my car when it had nothing but this exhaust and some crappy intakes.
Old 02-27-2023 | 09:24 AM
  #1883
jroptop's Avatar
jroptop
https://youtu.be/uW89JBuGFgU
I believe your setup is the full catback with the mufflers…I wanted to get more sound clips on the Topspeed pipes only that do away with the stock mufflers and the rest of the exhaust stock. I do love the sound of the full catback though!!
Old 02-27-2023 | 09:45 AM
  #1884
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
aaaah, gotcha, you were looking for the muffler delete thing. Sorry, top speed site wasn't loading.
Old 05-26-2023 | 12:15 PM
  #1885
AP's G37's Avatar
AP's G37
Actually the exact build I have right now. Had some trouble with fitment because of damage to the left pipes of my exhaust, but the right side fit fine (with some force). There are some sound clips on YouTube, like this one:
. That's actually the main video I watched when researching to buy this exhaust but there are other sound clips. My budget for exhaust was low, so I opted for this axle back. If what you want is SOUND on a budget, then this is the right option. However the sound is nowhere nearly as aggressive, deep, or toned as a full catback would be. I will say though that I'm happy with what I got, it's exactly what I wanted: something thats loud and actually allows you to hear the nice VQ engine sound that the G37 has. And thats only with the right side installed.
Old 05-26-2023 | 12:58 PM
  #1886
jroptop's Avatar
jroptop
Thanks for replying…Did tou have to cut off the end of the midpipe in order to slip joint the Top Speed to it? Also, the sound clip you provided, did it have the stock resonators and cats on it? It sounds great! To give myself an idea what it would sound lime, I disconnected the mufflers at the band clamp joint and sounded good, but not the same as the clip you provided. Let me know, and thanks again!
Old 05-27-2023 | 02:07 PM
  #1887
AScobi64's Avatar
AScobi64
Had my exhaust chopped together by a good local shop. Meisterschaft Y-pipe, Tanabe coupe mid-pipe and HKS Hi-power mufflers.
Sounds perfect for me. Good VQ sound, minimal rasp. Does have a little bit of drone around 2800rpm but it doesn't bother me much. Overall I'm pretty happy with how it turned out.
2013 Infiniti G37X sedan
Rochester (05-27-2023)
Old 05-29-2023 | 02:21 AM
  #1888
AP's G37's Avatar
AP's G37
When installing the axle back I did it myself with a friend so we were not nearly as experienced or properly equipped as a reputable shop would be when installing things like this. That being said, we were able to install it on the passenger side of the car (the side with no damage to the car). The fitment was not perfect, it took a lot of force to slip joint it as you put it into the stock mid pipe that comes with the car and a lot of force to put it into the hangers. I'm sure that in a shop they probably would've just cut and re-welded whatever they needed to to get it fitted perfectly, but I installed it myself without the proper tools so it was hard to get it to fit on that passenger side. Because of this, there is some gapping between the axle back and mid pipe which I tried my hardest to fix by just forcing the exhaust into the mid pipe but alas, its hardened metal and I'm not strong enough to bend it lol. Anyways, I'll be taking my car to the shop this week to fix the damage to my exhaust and properly install this axle back. Once I've got it back, I'll try and post some sound clips for you to hear. As for the YouTube sound clip I provided, that is with the stock resonators and cats. In terms of sound, the axle back is loud and really allows that signature VQ engine sound to come through. That being said though, it will be nowhere nearly as aggressive, deep, or toned as an exhaust with more modifications. Muffler deletes on this car tend to just be loud and raspy, which is exactly what this kit from Topspeed is, it's a muffler delete kit that gives you some cool new sounding piping. In terms of the rasp I would say it's really not that bad, at least with this axle back. What I want is loud, good tone, and good performance. I've done some research and if I don't like the way it sounds/runs once I get it back from the shop, I'm gonna delete the factory resonators and replace them with some 2.5inch inlet 12" Vibrant Resonators, replace the factory rubber ribbed intake hoses with smoother new Z1 Silicon Post-MAF Intake Hoses, and get a pair of aFe Magnum Flow DRY S air filters to replace the stock ones in my OEM air boxes. Should net me the result I want. As for why I went for the dry ones and not oiled, the oil messes up the sensors (BAD), occasionally gets sucked into the engine (WORSE), and are a hassle to maintain (THE ABSOLUTE WORST).
Old 06-20-2024 | 11:47 AM
  #1889
buddybash's Avatar
buddybash
I don't have a fly-by, but here is a stationary comparison of the 6MT Sedan, both with the Fast Intentions Resonated High-flow Cats.
First half is RHFC + OEM catback, second half is RHFC + FI 2.5" CBE w/18" res.
Excellent setup!
Old 09-14-2024 | 03:44 PM
  #1890
RobC7's Avatar
RobC7
Finally got the video edited.
Rochester (09-14-2024)
guy from norcal
04-23-2024 02:49 AM
Mkhlmnn
Video Share
08-02-2016 10:22 PM
Eyeshield25
Video Share
12-28-2015 05:56 PM
stm37s
The M - Spot
04-12-2014 11:01 AM
Quick Reply: The Sedan Exhaust Thread
