The Sedan Exhaust Thread
#1787
VQ's love resonators. Either in-line or j-pipe or helmholtz resonators, they all do the trick. Just tame the rasp while leaving the iconic VQ sound and still very good volume.
issa9002 (04-19-2021)
#1788
I am getting a custom exhaust done this weekend. I'll be posting pictures and video clips here and on my own thread once it's complete. Should be pretty sweet. I want to get into it so badly but I don't want to ruin the surprise lol
#1789
Sound clip of my car?-none yet, but on the way.
The following 2 users liked this post by afrayedknot:
hexotic (10-14-2020),
Pato A. Vidal (04-22-2021)
#1792
DIY Cheapskate/Mod
There's actually an AWD version of it. Someone here on the forums has the setup, they actually bought it used from the classifieds section.
https://www.youtube.com/watch?v=Y1W39hMo4X8&t=506s - here's a link to what it sounds like. (Starts to rev @ 8mins). Notice the metallic rasp sound when the revs peak. That's what I'm exhibiting with my set up.
#1793
This isn't my car. Exhaust consists of 1320 test pipes, no name X pipe ($30) , no name 14" resonators, and no name mufflers. Custom 2.5'' piping throughout.
V36 sedan custom exhaust - YouTube
#1796
Did you end up doing this setup? I would think it should sound pretty darn good! Normal muffler deletes on sedans are too tame for my taste. You getting test pipes and y-pipe should really sharpen the tone of the exhaust.
#1797
I started my exhaust journey 2 years ago with the proven Vibrant 1790 and Tanabe Axle-Back combo which achieved the throatiness that I wanted. Since then, I installed my ISR Resonated Test Pipes to replaced my bad cats which definitely enhanced volume, but introduces opportunity to reduce rasp and lower pitch due to the stock Y-pipe and shorter resonators. It sounds greater than when I started, but I'm definitely looking to deepen the sound without drone.
I don't want to pour more money into my car, so I want to keep my axle-backs.
Options I'm considering:
1) Custom 2.5 inch Y-pipe - match the outlet of the test pipes with the inlet of the midpipe. This would somewhat resemble the Stillen Exhaust setup and allow for a smooth transition into the 2.25 in mid-pipe and axle back. However, it may still rasp due to the 1790 resonators.
2) Custom Resonated X-pipe: Maintain a 2.5 in diameter throughout the system until axle-backs. A reducer would probably be needed and some accommodation would be needed to not alter the axle-back mounting. This is most likely to reduce rasp, but cannot be reverted to OEMish without full catback.
3) Custom X-pipe: Link the cat to mid-pipe and figure out how to reduce from 2.5 to 2.25. May drone and may look too "frankenstein'ed." cannot be reverted to OEMish without full catback.
What are your thoughts or opinions?
#1798
Carboy37 (12-03-2020)
#1800
Looks like you are following SCS custom cat back set-up. If so, kudos to you. I'm I. The process of doing the same, now waiting for delivery of my resonated x pipe/muffler and other parts. By the way is your car an awd? Keep us up to date on your progress and post some photos once you are done. Good luck!
