What is needed to make an AWD Sport into a true OEM Sport Package Sedan?
As some of you have read, I am not pleased with how the 2013 G37xs drives. I am not looking to push the car hard or race but this car is just a sloppy boat for daily driving. My Moms BMW X5 SUV handles better day to day, and feels more secure on the highway.
What parts would be needed to turn this slop into a true Sport Package sedan (same as oem rwd sport package, of course keeping it awd).
I read the true sport package has quicker steering, I will not take apart that aspect of the car as it seems not an easy attempt. Also, I believe the OEM true sport rwd sedan has lsd which cannot be added to the awd.
Is the only other difference the oem sport shocks/structs, oem sport springs, and rear thicker sway bar?
Will adding the above cause any issues withnthe awd system? For example, I know the awd need all four wheels to be exactly the same or it could cause issues. Anything similar with adding the oem sport shocks/struts, springs, and thicker rear sway bar?
Lastly? is there any other differences between the true sport and the awd sport?
claudiohv (12-10-2015)
Things you can do: tires, sways, suspension, and brakes.
Thinks you can't do: steering, LSD, 6MT.
You already have the appearance considerations.
You read my other post and I see you underlined tires, do you think that is going to give the car a completely different feel? More like a sport sedan then a boat?
Do you think just tires and sways will make this car behave more like I was expecting?
I know I sound like a broken record but Swift Spings, and swap the Rear Sway bar with the 37S sway bar. Feels great after that swap. Highly recommend the Swifts for the 37xS.
One was not thicker than the other.
I say go big or go home. Forget swapping for oem rear sways like the 370z or whatever everyone is saying. Go for Hotchkis or Eibach.
Heck, he might still have it in his basement somewhere.
The G37 and G37S rear sway bars are the same. I believe someone here purchased the G37S rear sways from Rochester thinking they would be a upgrade over his G37 rear sways and upon visual inspection both of the rear sways looked identical.
In OEM configuration, the only thing making the RWD Sport Sedan (and 6MT) feel more sporty than the RWD Journey Sedan are the shocks, steering, and staggered 18" rims with summer-only tires.
I would look online to see if the part numbers for both are the same. Note that a few mm difference would make a difference, and I doubt that would be visible to any any of us.
"Diameter is generally the easiest concept to grasp, as it is somewhat intuitive that a larger diameter bar would have greater torsional rigidity. Torsional (or twisting) motion of the bar is actually governed by the equation:
twist = (2 x torque x length)/(pi x diam^4 x material modulus)
And since "diameter" is in the denominator, as diameter gets larger, the amount of twist gets smaller. Which, in a nutshell, means that torsional rigidity is a function of the diameter to the fourth power! This is why a very small increase in diameter makes a large increase in torsional rigidity."
Sway Bars - How they work and how to choose the right size for your needs - ProbeTalk.com Forums
Update...
Looks like they all use the same PN after all: https://www.myg37.com/forums/g37-sed...upgrade-3.html
"56230" - http://parts.infinitiusa.com/nissanp...intvehid=17607
Update...
