Help! Push button stuck in ACC position
I was getting back into the car, put foot on brake and pushed start button and everything turns to the ACC position, GPS screen turns on, radio turns on, dash lights up and door ajar message comes on middle screen and starts to chime... and that's it... won't start and won't turn off... even when I close the door it still says door ajar and chimes as if the door is open. Had to walk to Target, buy a wrench and take the battery cable off... then it acted completely normal again... done this twice over the past few weeks. Dealership couldn't replicate it. Any ideas???
Telcoman
I've had a similar problem. Mines would turn to on but would never start. I had to throw it in drive and back to park and then it would let me start. Like the parking brake switch never registered. Happened twice so far since I bought it
MStrike (11-24-2020)
I took telcoman's advice and had it towed to the dealer... it did it again this morning... I will keep you posted on the outcome. The lease is almost up and I had considered buying it since I have aftermarket exhaust, wheels, and Eibachs and I love the car, but now I'm considering just turning it in and leasing a new one.
telcoman (07-17-2015)
Similar problem. Mines is stuck in the on position. Just bought mines from an auction site and was letting the locksmith program a set of keys for it but he couldn't finish the process because it can't turn back off. Any suggestion on things I may try
Parts Specialist
There is a TSB to correct that issue. Our G37 sedan did the same exact thing a couple times, no problems since.....
http://infinitig37.com/TSB/ITB12-024.pdf
List of TSB's:
http://infinitig37.com/Infiniti-G37-...Bullitins.html
List of TSB's:
2011 g37x sedan won’t start
I have a 2011 Infiniti G37x , I went to the store came home & tried to drive the car two days later & there was water on the passenger side floor . It also wouldn’t start . It just gets stuck on the the on position but the car doesn’t start & hitting the start button it’s doesn’t go back to the off position unless you disconnect the battery . When the car is off It flashes the security indicator light even with the key in the slot . I changed the battery & brought a new positive battery post , still won’t start . Please help me with a solution if you can , I take care of my car , it has to be something minor like a rest or fuse change or something .
Hey! Did you figure out what the issue was? I’m in a similar situation.
37
10-17-2020 11:12 AM
Msherburneg37xs
Intake and Exhaust
09-30-2015 06:39 PM
r0cketm0nkey
09-27-2015 01:34 PM
