Shifter boot replacement
Wrap your fingers into the boot at the trim edge next to the heated seat dials, and pull it upward; it will unclip with a little bit of force. Of course, then you have to unscrew the shift ****... which is usually something that destroys the ****.
So I should just leave it as is. Why does it destroy the ****.
First lift the boot off as Rochester stated. Follow steps 1 and 2 below.
http://www.activetechdesigns.com/downloads/MT-G.pdf
Then remove the **** using these instructions. Same exact procedure on the G.
OEM shift **** removal (SEARCHED) - Nissan 370Z Forum
Here's a link to the wrench...
Alternatively you can use a cut peice of radiator hose following this guide.
2003-2008 Nissan 350Z Shifter **** Removal Procedure | Nissanhelp.com
BOA BO13010 Constrictor Aluminum Strap Wrench - Adjustable Wrenches - Amazon.com
Victory
17
10-27-2022 03:45 PM
SuicidalG37SGuy
09-10-2015 06:01 AM
