Oil & Grounding
Oil & Grounding
OK, long story short. Bought my first Infinity in September ('09 G37xS), and love it. A moth after I bought it, I was rear ended by Larry, Daryl & Daryl in an '95 F150. Car was down more than 2 1/2 months for repairs. So I am now just really getting to know the car.
Question #1: Car just turned 100k miles last weekend, and is due for my first oil change (Infiniti dealership did one right after the accident). They (the dealership) are telling me I should not do Full Synthetic because of the teflon coating on the rockers (wont stick), and that they recommend Synthetic Blend. I cannot find anything on here confirming this. Comments?
Question #2: Car idles a little rough. Also on a cold warm restart, it will start, then immediately die. Restart is never a problem. Would a grounding kit solve the rough idle?
Thanks.
Thanks.
I'm a n00b here and still researching the car I wish to purchase in the next couple of months but from what I've read, you may want to try cleaning your MAF sensors and throttle bodies with their respective cleaning solutions as a way to fix your idle issues. There's a few DIY's in that section.
Clean out your TB and MAF here are some DIY i made a DIY for the MAF on the g35driver site. Good Luck
And +1 on the seafoam
DIY: Clean your throttle bodies - G35Driver
DIY Mass Airflow Sensor Cleaning MAF - G35Driver
https://www.myg37.com/forums/d-i-y-i...1-seafoam.html
My dealerships tells me regular correct weight 5w30 motor oil is fine.
I would look into throttle body and MAF
More importantly at 100k you should be doing the plugs.
RexHavoc
10-02-2015 11:47 AM
Junchao Sun
25
10-01-2015 12:41 PM
