Question about start up (buying g37)
#47
I'm not sure what the cutoff date was for latest TSB, the dealer will be able to look up your VIN # and see if your vehicle has or hasn't been updated.
When you go to the dealer you need to state that your G is experiencing lagging/hesitant shifting for them to go through the TSB process (at least that's been my experience). As far as the cupholder, that depends on dealer discretion, it may or may not be determined to be a warranty item
And like I said, that price seems fair if the G is in reasonable condition, and it sounds like it is
#48
And looking at your G it seems to be in nice condition, I would look into replacing those All Season tires w/ summer tires when you have the budget, you'll get much better overall performance from your G w/ stickier rubber
#49
It wasn't me who mentioned a specific dealer, but your closest Infiniti dealer would be where I would go, they should be able to help you.
#50
For about 30 to 40% less the Toyo T1 Sports are a great option, have excellent wet & dry grip but will wear faster than the Pilots, they also weigh a bit more.
Here's a good vendor for those tires, Andrew is the guy to talk to and gives nice deals when you mention myG37.com
I'd run a 235/50/18 front 255/45/18 rear to give you a bit more
tire on the road for a bit more planted feel.
Here's the links for those two sizes
TreadDepot.com: Toyo Proxes T1 Sport Tires Black Wall (235/50Z R18 101Y) 252290
TreadDepot.com: Toyo Proxes T1 Sport Tires Black Wall (255/45Z R18 103Y) 252280
#51
If price isn't a problem than Michelin Pilot Super Sports are the gold standard, great wet & dry grip, lightweight, and wear very well for a softer summer tire.
And I need a suggestion for a good but not expensive oil pressure gauge (pref. electric and not analog) I have 4 months left for B2B warranty and about 2.5 years of Engine / Drivetrain. if I find out the oil pressure is low at idle / 2k RPM, which is most likely a paper gasket is blown , is that covered? Meaning, will they upgrade it to the new metal gasket or...
Thirty_Seven
12
08-16-2015 01:48 PM
