Car Won't start but power to accessories
Old 03-08-2015, 04:00 PM
calvin_hobbes
calvin_hobbes's Avatar
Hi All,
My 2009 G37S will not start.
I get power. The ACC will turn on and so does the ON button. The lights, radio, seat etc seem to work.
But if I press to start everything shuts down and turns off.
Battery is a second battery installed July 2013 from Infinity dealership.
I tried jumping to no avail.
I currently have a DieHard charger charging the battery, but i am not optimistic as I tried to start it with the same results.
It currently shows 95% charged.
I have a brand new battery in the key fab too.
I am able to apply the parking brake and and get shift release to go into neutral, and the wheel turns slightly so I can get the $105 tow to infinity tomorrow morning if I have to.
Any ideas?
Old 03-08-2015, 04:33 PM
vqsmile
vqsmile's Avatar
If all is as you say, it would certainly seem there's something amiss elsewhere in the electrical system. I would measure the battery voltage with it installed in the car: before, during, and after attempting to start it.
Old 03-08-2015, 05:05 PM
calvin_hobbes
The percentage charged I believe was at 60% when hooked up the die hard charger. It is at 100% now. After I try starting it, which does nothing, it drops back down 90%.
Blown fuse? Not sure where to even check for that
Old 03-08-2015, 05:15 PM
vqsmile
vqsmile's Avatar
^^ I specifically meant actual voltage, not charge percentage. If there is a short or some other excessive current draw happening, versus an open circuit/ blow fuse, you should be able to see/impute it in voltage fluctuations.
Old 03-08-2015, 05:27 PM
calvin_hobbes
Well. I just got it to start with the die hard attached. This time I pressed realllllllllly hard down on the brake while starting....after about 15 seconds it started. I let it idle for about a minute and tried restarting with the die hard and it started up again. I am hoping that is good enough to get it to the dealer in the morning. I would assume this means IT IS the battery.
Old 03-08-2015, 05:31 PM
vqsmile
vqsmile's Avatar
If just pressing down extra hard on the brake pedal made it start, it would sound to me it's more like the 'brake pedal depressed' switch (i.e. interlock) is failing or not adjusted correctly.
Old 03-08-2015, 05:58 PM
calvin_hobbes
Thank you..very good point......I will bring that up to the dealer tomorrow morning.
Old 03-11-2015, 01:49 PM
Glenn2008
Glenn2008's Avatar
I just found out that my car won't start. The battery seems fine, the car turns over and seems to want to start, but no success. I'm charging the battery now. I've pulled off the air ducts and moved the TB's, so they are free. Any other suggestions are welcomed.
Old 03-12-2015, 12:30 PM
vqsmile
vqsmile's Avatar
Start your own thread.
telcoman (04-01-2015)
Old 03-12-2015, 02:06 PM
GAWD
GAWD's Avatar
Any check engine lights on?
Old 03-12-2015, 06:05 PM
Glenn2008
Glenn2008's Avatar
^I found the problem. #1 plug was fouled, #5 plug had a long crack in the porcelain. Once I changed out the plugs, the car fired on the first try. The plugs were factory installed, car now has 80K. I believe that the #5 plug was not torqued properly, but I can't say for sure. It didn't take as much effort to remove as the other plugs. I purchased plugs for the car a year ago, but didn't install them because someone posted up pictures of their plugs at 110K and they looked like that they were good for another 50K. Fortunately, the fix was easy. Thanks to the many DIY;s on this site.
Old 03-12-2015, 06:08 PM
Glenn2008
Glenn2008's Avatar
No check engine light was on. It just wouldn't turn over. I brought the car to AutoZone after I got it started to see if they could check if there were any codes with the OBD II, but they told me that if there were no CIL, it would be useless.
Old 04-01-2015, 11:47 AM
newusernamerequired
newusernamerequired's Avatar
I have that problem now, I'm getting power to the ACC light, and the radio works. But the engine just won't turn. Should I just try to jump start it? and what is the solution for the this problem ?
Old 04-01-2015, 11:48 AM
newusernamerequired
what plugs?
Old 04-01-2015, 03:05 PM
tite_tite
tite_tite's Avatar
Originally Posted by Futtbucker
what plugs?
spark plugs i believe
Quick Reply: Car Won't start but power to accessories
