High idle after test pipe install
Hey guys whats goin on. Thought i fixed the problem but it came back.
So i installed some megan resonated test pipes last week. After a couple days my idle was stuck at 1k rpm. I did the idle relearn pedal relearn and throttle relearn. Nothing. I then unplugged the battery overnight. Came back the next morning and it was back to normal. CEL obviously for test pipes but after a couple days the high idle came back. Is this normal for my car with no tune? I do smell the ecu dumping alot if fuel and get alot of popping. Please help me out. Im not ready for a tune yet. Still waiting for a CBE and intake.
Clean your throttle bpdies and do a throttle relearn that might help since there's nothing else you can do. There is a DIY somewhere in here. DISCONNECT the battery before doing it. Get an OBD-2 scanner that connects to your computer so you can check your AFR they are like $20 on ebay and it reads everything.
Sent from my LG-MS870 using IB AutoGroup
wattles
09-30-2015 09:19 PM
