AC Evaporator Drain Hose Location
I have been concerned about the location of the drain hose as I seem to have the water come out of a crack in the passenger side frame. The car was undercoated by the original owner at the Dealer and I am not sure if they covered over where the drain hose should be. I also discovered they got undercoating on the drive shaft, the one that goes to the front wheels (AWD) and on the ones at the rear. I can't believe they never noticed or did anything at the same Dealer during any of the work the original owner had or the times I have had it in for servicing. I spent the afternoon removing it from all of them. I have attached a picture of the small crack that I have the evaporator draining from.
Thanks, Brian.
Thanks, Brian.
A 1/4 mile @ a time
The AC drain hose is inside the body by the right rail at the front of the car. There is a hole just in front of the rail and to the right, its in there, I assume that that is where its suppose to drain out, but the tube isn't long enough. Mine drips out of a hole on my rail.
.. The car was undercoated by the original owner at the Dealer and I am not sure if they covered over where the drain hose should be. I also discovered they got undercoating on the drive shaft, the one that goes to the front wheels (AWD) and on the ones at the rear. I can't believe they never noticed or did anything at the same Dealer during any of the work the original owner had or the times .
The dealer made a nice profit selling worthless and unneeded undercoating.
Telcoman
Kojack
10-09-2015 05:53 PM
SON415
09-28-2015 05:49 AM
