Mods to make my G37 similar to G37s
Because Racecar
I will be putting on my swift springs on friday! So excited! As for tires and rims they will have to wait. But what i'm interested in now is sway bars. If i shall get some what brand? Should i just get 1 sway bar and put it in the back and set it to soft to contradict the understeer? What do you guys think?
Lances Infiniti (08-06-2014)
GTSpec rear subframe and rear lower tie braces + S rear sway bar. Just put the rear sway on today after the other two braces and now it's on rails! You could get a Hotchkis bar but it might be too stiff. I now have NO body roll and the only limiting factor is the grip of the tires. The car is not rough on bumpy roads and does not lose traction on bumpy roads like my friends 370z. The 370 is too stiff for normal ****ty USA roads. $250 for the two braces plus <$100 for a used S rear sway. Change your tires from 225/55/R17 to 245/50/R17 (Continental ExtremeContact DWS) and you'll be smiling.
Why buy both? I'm just wondering your reasoning Gofight. Also i just want to improve handling and not intensify understeer or oversteer. What would i set them too for that?
I'm sorry, but I have a hard time believing upgrading to an S swaybar + chassis braces + "high performance" all season tires is going to equate to "on rails" handling
I have Eibach sway bars and I can attest to them not being "too stiff". Even with dedicated summer tires I still think the handling leaves something to be desired.
Hey OP, aren't you the guy who commented on my swaybar pic a few days ago? Based on the PM's you sent me, and this thread, my advice is that you continue researching things to get to whatever comfort zone you need in order to just buy some aftermarket sways, front & back both.
Hotchkis, Eibach, Stillen, Whiteline, whatever... doesn't matter. You will not regret it.
Feel your wallet getting thinner yet? Yeah...it doesn't stop once you start. Know upfront exactly where you want to go with it so that you're not buying s**t, installing, then rethinking it things and selling what you just installed only to get something a bit better. Have a plan and work the plan. Just my two cents buddy. Have fun with it.
On rails
UHP Summer: http://www.tirerack.com/tires/tests/...y.jsp?ttid=163
UHP AS: http://www.tirerack.com/tires/tests/...y.jsp?ttid=177
I have had the Conti DWSs on my X for about 20k and am not overly impressed with them. Their wet weather performance is very good and they handled so-so in snow conditions. According to sources like Tirerack, they seem to perform well in all the categories for an all season tire, but now that I have 20k on them they have definitely worn a lot faster than I would've expected. Maybe it's my driving or just the G's setup, but their right around 5-6/32 of tread all around. My biggest complaint with these is the lack of steering feel and initial turn-in... they just feel floaty compared to the OEM Goodyears. I've gained a little of that feel back now they have worn down, so I'm not sure if it's the tread pattern or sidewall construction but it makes the G's steering feel worse than factory stock. The other thing is they tend to squeal more often than when they were new, especially when going over painted lines, etc.
Numbers and ratings are just that, but they don't always translate into a perfect setup IMHO. I'll be looking to replace these with something else soon.
Bottom line: They cannot be compared to a true summer tire in terms of their dry performance and road feel. If you want a true performance-oriented tire go with a dedicated summer tire and get snows for the winter (unless you're in the South).
Where do you drive? Are your road conditions autobahn smooth? (I have just returned from Germany and have driven my pre-rear sway setup on the autobahn at 145+ mph.) I have an X so I have no traction issues whatsoever. Things may be different with a RWD G like yours as with the 370.
I don't have any traction issues. I'm not sure where this assumption of losing traction you have comes from
Do you have any data to support the braces do anything? Like increases stiffness X%? Track times before and after to show an improvement? If you added both at the same time, how can you isolate the improvement of the braces v/s the S sway bar?
Your experience is counter to the vast majority of G and 370Z owners regarding sway bars.
IMO, Braces = Placebo effect.
Also, the DWS's are UHP not HP. If you compare UHP Summer and UHP AS, the AS handles better in the wet, so unless you have Max or Extreme Summer tires, then you are not going to notice that much of a difference. You will also be spending a lot more on tires given the initial cost and the treadwear ratings.
Because Racecar
I'm in agreement that tie braces are mostly a placebo. Strut tower braces are also a placebo, they were an aesthetic decision I made. You can't even see tie braces, so you don't even get the aesthetic appeal.
IMO, the chassis is so stuff already that additional tie braces are just adding weight.
Lego_Maniac (08-08-2014)
#29
I think there is a little bit of float in the suspension and that some additional shock dampening would help. I'm comparing this to our old E90 325i Sport and other E90 Sports I've driver
I'm in the south. Our reads are pretty smooth because we don't get much freezing weather to expand/contract the roads.
I paid less than $350 for my aftermarket sway bars.
AS tires do not handle better in the wet. The only thing AS tires do well is bridge the period of time between summer and snow. Dedicated summer tires perform better in the wet and dry at above freezing temperatures. And winter tires perform better than AS tires once there is snow on the ground.
Well, we all know BMWs handle amazing. I wanted a 335i x-drive, but couldn't justify the extra price and often over-engineering.
The braces completely removed my body roll. I installed the braces and sways at different times; the braces first. We have different vehicles, so our experiences will be different. I have been trying to find a 300ft parking lot or paved area to use my bluetooth OBDII adapter, but that is difficult. I just know the speeds at which I could take turns on my favorite roads before vs. now. The rear sway helped braking stability for sure as well.
