MPG & Other Options
#47
Best I got was around 26mpg, punched on the ramps, but a smooth sailing 75mph most of the way, think that's pretty good. Probably float around 17-21mpg now, but I rarely check (fill up a little less than once a month now ... 93 octane for $3.30!)
Not sure how you get poor mileage on the highway, do you guys randomly floor it or something?
#48
Just checked air filter. Its almost new.
I have been driving like a grandma, did a reset of the MPG computer, got 18 on the way home. 50 MPH highway almost the whole way.
Something is up...
While I agree, the G is much much much more capable from a speed perspective, I can't really use any of that around here, so I am finding it plus the 93 octane required painful...
Something is up...
If it were resistance, like a wheel bearing seizing, I think the failing component would have exploded by now. I don't see low tire pressure taking off 6+mpg. Even seized brake calipers probably wouldn't cause this large of a drop and you'd probably smell burning brakes if it were.
Check underneath the vehicle. I've watched significant mpg drops when the aero shields under the car were missing. Make sure nothing's wrapped around the driveshaft or any other components.
Dirty air filters would not cause this large of a drop. The computers in today's cars make concessions which minimizes any losses for mildly dirty filters.
I could see really bad gas doing this. Get Top Tier gas from a known good station - avoid supermarkets, discounters and Costco. Check your spark plugs and make sure they are in good condition and burning evenly. Check your thermostat - is the engine getting up to temp? Could be stuck open which leads to some loss in mpg, though I doubt as big as you're seeing.
That leaves a couple of questions: is your vehicle stock or do you have engine, wheel or other mods? Also, it is an auto are you leaving it in D or DS?
I don't mind 17mpg or lower when I "earn" it, but if I'm driving like a grandma my G37 can do 27 on the highway and even 31 with a stiff tailwind.
#50
#52
Wawa is not listed on the top tier website. In addition, all of the Wawa gas stations I've been to only pump up to 91, if I recall correctly.
37
10-17-2020 11:12 AM
04G35NYC
07-19-2016 01:42 AM
mjnoles1
10-04-2015 10:27 PM
