Question on parts
Old 04-30-2014, 01:18 AM
sicko
sicko's Avatar
Question on parts
I have a 2010 G37 with a Takeda intake with a OBX axle back exhaust. Would you get a berk HFC or a Motordyne M370? I have read that either is good but both does not really add a lot more power. Please need input.
Thanks
Old 04-30-2014, 03:05 AM
'11G37S
A 1/4 mile @ a time
'11G37S's Avatar
From what I've heard and read, the HFC is one of the best bolt ons you can do to increase power. I haven't done much research on the 370. There are a few guys on here that have done a lot of research on the 370 and some that have it, I'm sure they'll chime in soon.
sicko (04-30-2014)
Old 04-30-2014, 03:58 AM
RexHavoc
RexHavoc's Avatar
I would go HFC over an M370. The cats seem to be the biggest bottleneck in the system. Full disclosure, I don't have the M370. I'm on the fence whether I will pick one up before I get tuned.
sicko (04-30-2014)
Old 04-30-2014, 07:16 AM
08Gsmith25
08Gsmith25's Avatar
is the 370 the lower plenum collector? i was under the impression that did not give you much....cats are the number one mod for this car and most others i would assume
Old 04-30-2014, 07:48 AM
GoFightNguyen
Because Racecar
GoFightNguyen's Avatar
The M370 is the upper intake manifold, it goes between the top of the cylinder heads and the throttle bodies.
Old 04-30-2014, 08:00 AM
connoisseurr
connoisseurr's Avatar
My opinion on the M370 is the following. It's another breather mod that allows for additional airflow into your engine. I would really only add this if you had an upgraded intake AND a full exhaust. My reasoning for having these parts is, you can only push as much air into your motor as you can push out - meaning, get rid of your exhaust restrictions (OEM cats, and exhaust if you so choose) to allow for the additional air being allowed to enter the engine.
Another point regarding the M370, having this, along with other breather mods, can cause your engine to run lean. This is why most recommend getting a tune along with the installation of an M370.
I have a full exhaust from Fast Intentions and I have a long tube cold air intake. I plan on purchasing an M370 manifold or Z1 manifold and installing it just before I get a tune. That way, the engine isn't starved on fuel and when tuned, it will operate at a better frequency with the added air and fuel working together to make a bit more power.
Hope this, and the notes from others helps.
sicko (04-30-2014)
Old 04-30-2014, 09:00 AM
Received 4,722 Likes on 3,527 Posts
This, and the long-tube intake design... which you already have, OP. Get the cats.
There also seems to be a common opinion that non-resonated 200 cell-count cats can be raspy when matched to an aftermarket cat-back, so look into that. Alternatives are a 300 cell-count catalyst, and/or built-in resonators. ARK and Fast Intentions both sell resonated cats, but with different tech on the resonator.
sicko (04-30-2014)
Old 04-30-2014, 10:28 AM
sicko
sicko's Avatar
Thumbs up
Helps a ton! Thanks bro...
Rochester yes I must look into those cells not really into the raspy sound...lol Thanks
Old 04-30-2014, 11:11 AM
connoisseurr
If you're going for cats and you don't want rasp, get your name on the list for some FI RHFCs. There will be a lead time but it's well worth it. Drop Lance a line, or give Tony at FI a call.
Old 04-30-2014, 11:20 AM
That would be this Group Buy thread: https://www.myg37.com/forums/group-b...uy-thread.html
And these be the Resonated High Flow Cats:
Old 04-30-2014, 11:22 AM
GoFightNguyen
Because Racecar
I have nonresonated FI HFC's and a 12" FI catback. No rasp!
Old 04-30-2014, 11:24 AM
You also have a Coupe, with a different design exhaust. I bet you that's the diff.
Plus, rasp is so subjective. One man's racket is another man's win.
Old 04-30-2014, 11:26 AM
GoFightNguyen
Because Racecar
Plus, rasp is so subjective. One man's racket is another man's Nguyen.
Fixed.
Slightly different, but fast intentions is a dual canister exhaust, regardless of sedan vs coupe, right?
Old 04-30-2014, 01:18 PM
ANMVQ
ANMVQ's Avatar
Go FI RHFC's When I had mine I loved them. I WILL be getting a set again . The power you pick up in the mid range is very much worth it. Light Red and light blue is my unturned run with Takeda's, FI RHFC and exoticspeed cat back, the dark run is my TUNED with Stillen Gen 3's and cat back only-no HFC's-.
File Type: pdf
Old 04-30-2014, 01:22 PM
sicko
sicko's Avatar
ANMVQ Im looking into it but right now but just missed the group buy. So looking for a used one and maybe a FICBE.
Quick Reply: Question on parts
