Why was a Sedan your choice?
#106
Nothin2,
Don't agree with your statement on the G being too small to justify a sedan. I need a sedan to be able to occasionally haul an extra person or two around. The G is just big enough, with just enough rear seat room, to do the job. I would have been okay with an A4/S4 too, but the A4 was too slow and the S4 too expensive and unreliable.
I agree with you on the coupe styling - always liked the look, especially in the rear, a bit better. And they are much easier to find in 6MT. But when I drove a coupe 6MT and adjusted the seat where I could comfortably use the clutch, the drivers seat was basically touching the back seat. The 335i coupe is much better from a rear legroom standpoint, but reliability and ownership cost are big drawbacks.
Greg
Greg
#107
I get what you're saying gsm and I respect your position, but a quick question for you. When you said you adjusted the seat in the coupe where you could comfortably use the clutch it was nearly touching the back seat correct? Now let's flip to your sedan when you drive normally and have your seat optimally positioned for clutch use, how much rear leg room is left? I would bet it isn't substantially more than the coupe... Correct me if I am wrong.
#109
Prior to the 745 we had an 07 G35 sedan, and that was bullet-proof so we got rid of the cash-sucking 7 series and returned to the 09 G37 Sedan. My wife does in home day care and needs room to easily haul 3 kids and it's her daily driver so the sedan was the easy pick. If it was my DD it would probably more closely resemble your 6mt though
#110
Nothin2,
Actually it's a lot more ... just measured 7 inches to the top edge of the rear cushion. To be fair, I've installed an RJM clutch pedal on mine, which lowered the engagement point a bit. Also, the seating position in the sedan seems quite a bit different. Generally higher, and you naturally sit more upright. Or that's the way it seemed to me based on one test drive of a coupe.
#111
Deelow (02-15-2014)
#113
The last coupe I had caused a problem when I parked against a wall in a public garage and some idiot parked too close to the drivers door for me to get in. Those big doors can be a problem.
#114
That said, I look at the G coupe community for inspiration in modding (mostly cosmetic), since the group as a whole is more active. Even in 2-door form, the G still offers undeniable value in its segment (370Z notwithstanding )
#115
( feel the same way about the Z cars - I consider the "sharper" 350 waaaaaaaaay handsomer than the blockier, stubby looking 370 - just say'n ).
#116
I agree that the Coupe community is far more active, so it's a pleasure to be combined on this board. The Q50 boards are a bit light on activity.
#117
I see a common statement made that the sedan is "faster" than the coupe. I understand this is a moot point due to the negligible differences in weight and power, but I guess it rubs me the wrong way since the information I found does not support this statement. I ran the numbers posted by Infiniti and I don't see an instance where an equivalent sedan comes out with a better lb/hp ratio. It is more likely that manufacturing differences in actual hp output, or driver weight, would bear more significance, but I wanted to post this as a reference or point of discussion. I guess what I'm trying to say is I don't see how this could be a reasonable factor in purchasing a sedan, or a coupe.
Hopefully this helps.
RWD:
Sedan: 3628 lbs / 328 hp = 11.06 lbs/hp
Coupe: 3633 lbs / 330 hp = 11.01 lbs/hp
AWD:
Sedan: 3822 lbs / 328 hp = 11.65 lbs/hp
Coupe: 3834 lbs / 330 hp = 11.62 lbs/hp
RWD:
AWD:
#118
The weight difference is around 5-10 pounds. That's about what my laptop bag weighs. Not sure this is even worth talking about as an aftermarket set of tires could add or subtract more weight than this...
#119
Well, that clears that up for me. Good to know.
I suspect the added 2 ponies are a factor of the different exhausts. Anybody know why they'd be different?
#120
You're right. If you research the spec sheets on infinityG37.com, the weight differences are negligible. I must have had that 100 pound number stuck in my head from a misinterpretation in models (AWD, RWD, 6MT).
