Back up camera
Back up camera
Hello all! I'm a newbie with a few questions!
I have a 09 g37x
I was in a accident last month due to snow and when my car was being pulled out my trunk was damaged so it was replaced. The replacement trunk has a backup camera, which my car previously didn't have. So my question is, is this a simple connection? I assume the wiring is there in the trunk just maybe not in the rest of the car? I would really like to get it hooked up!
Thanks in advance for your answers!
Sam
I have a 09 g37x
Sam
Because Racecar
I have a 09 g37x
Sam
I have a 09 g37x
Sam
LOGICALLY, it would make sense for the wiring to be there, because it would be cheaper to make one standard harness. Take off the back panel on your trunk and see if the camera harness is there.
If not, you would need to run the following:
I've had to do this exact install on the 2012 Jetta I had before. The only thing I didn't get were the "approximation lines" (the yellow lines that tell you where you'll end up).
Let us know what is discovered by checking the wiring in the trunk lid!
- Rear view camera (RVC) video cable to front of vehicle
- RVC 12v power to front of vehicle (fuse box)
- Reverse wire tap (to reverse lights within tails)
- Grounding wire (somewhere on trunk lid
Because Racecar
Why would a sedan with no nav and no camera have a screen? Please clarify if I'm wrong.
This is what you need bro.
Pac-Audio.com Product Details | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
I cant find the threat at the moment but basically this unit connects between the LCD screen and your AUX in the glove box. When you put it in reverse, the AUX kicks on and your camera works.
You can find the unit cheaper on line.
GoFightNguyen (01-13-2014)
Found this thread and it should answer the OP's question.
https://www.myg37.com/forums/audio-v...up-camera.html
