Sedan Chat Thread
Old 02-21-2022, 06:00 PM
  #13681
RobC7
RobC7's Avatar
Originally Posted by iCrap
So last time I changed the oil in my car was almost 2 years ago, 2/20/20.... But I've only driven 3,000 miles since then. Change it, or leave it? I imagine its probably fine.... Didn't realize how little I drive my car since WFH lol.
I wouldn't lose sleep over it, however I would change it as oil degrades over time and you want to avoid access moisture.
rotarymike (02-22-2022)
Old 02-23-2022, 10:02 AM
  #13682
BULL
Moderador
BULL's Avatar
Well it's time for new front brakes again
I tried to get away last year by replacing rotors with Centrics and flattened my old centric pads but over 4 month later I was warping again.
This time I'm thinking about buying a new set of Centric rotors and pads then resurfacing my old rotors for spares.
I have a buddy that will resurface rotors but needs to be on his time and I daily my car. I just can't take the warp anymore.
Lastly It seems like my slow water leak is coming from the glass and not the sunroof vents
So about $600 on just brakes and glass.
Old 02-23-2022, 10:08 AM
  #13683
rotarymike
Moderator in Moderation
rotarymike's Avatar
I'd see if you have an OReilly's in the area - they turn rotors in house while you wait. $15 or so. I'd also try new pads - it's VERY unlikely you're actually warping the rotor, more like leaving pad deposits. That combo shouldn't hurt TOO bad.
The water leak - man, I drove my car for over a year with no interior after it got flooded out in Matthew; I feel you. FWIW, a simple thing to try before you reroute the front sunroof drains is to just clamp them shut along the A-pillars. It will force the water to drain out the rear drain hoses (which rarely are an issue). Doesn't look too cool driving with no A-pillar trim and a hemostat on each side, but it works to troubleshoot.
Another spot to check is where the bottom cowling around the windshield sits - there's supposed to be a felt gasket between cowling and windshield that keeps rain from running straight down into the HVAC blower housing. You might want to pull that trim and weather-strip it with RTV when reassembling.
Old 02-23-2022, 11:07 AM
  #13684
Received 4,726 Likes on 3,531 Posts
Google "myth of warped rotors" for more info.
I gave up railing against the wind years ago, and just came to accept the phrase "warped rotors" as something that describes the situation, and not something literal.
Old 02-23-2022, 11:22 AM
  #13685
rotarymike
rotarymike's Avatar
Fair enough. The single-thickness non-vented rotors on my wife's Saturn or the early 1st gen RX7s would definitely warp - you could see the runout on the lathe prior to cutting them. But with a vented (IE, cast two-surface) rotor... especially ours, whether the small or large brakes... would take a level of force that would likely destroy other components as well.
This is why I'm picky on my brake pads. Honestly, these Hawk 5.0 get one more brake system bleed to sharpen up or they're going to be replaced. Too much mush, even though they do stop well. Pedal feel sucks.
Old 02-23-2022, 03:16 PM
  #13686
SonicVQ
SonicVQ's Avatar
Understood...
My original 11 year old, 115,000 mile rotors are "warped" and I will be using a deflection gauge to understand "warped" vs thickness variation vs pad deposition... once my garage get above 50F
Old 02-23-2022, 03:50 PM
  #13687
I hear you, Mike. Conventional wisdom makes it easy to accept the idea that rotors are "warped" when the brakes start oscillating.
But the phrase "conventional" doesn't imply inherent truth, that's always been a misnomer. Actually its an extension of the word "convenience". In other words, wisdom born of convenient logic, not empirical evidence.
That said, if you can prove otherwise, that's cool. I'm not married to the idea, LOL
Old 02-24-2022, 08:37 AM
  #13688
BULL
Moderador
BULL's Avatar
Based off the many rotors I've seen in my life get cut they definitely loose their straightness. You usually see this a lot more in automatics being that 98% of folks keep the brakes on while waiting for a light/traffic/etc.
In S. FL is actually pretty common due to traffic and sporadic rains, going through puddles will introduce water to a hot rotor and warp it. For automatics sitting in a light for 3 minutes forcing contact to a hot rotor thus keeping the heat concentrated on this part of the rotor while the rest cools is another reason. Maybe the word warped is incorrect however there is surface distortion.
For the experiment, things like climate, drive train type, rotor/pad quality and driving patterns will need to be taken into consideration. Seeing a rotor in a lathe where the hub is in perfect condition but you can visually see the braking surface of the rotor wobble is pretty common and has been for decades. You are able to visually tell if it's a pad issue however once they glaze, distortion is inevitable which is why new/freshy cut need to have a rough surface somewhere between 40-120grit in comparison.
This finish will help grab pad material and expel it as it leaves the pad. Too fine of a finish will clog the rotor and glaze it, too rough of a surface will kill the pads prematurely.
I've gotten away with resurfacing pads in the past but this last time it was my own damn fault, Rushing, not caring, blah.
PS the water leak is coming from the cracked windshield, did a water test focusing a stream on the cracked areas and not the roof and saw drips inside the car. Good thing I have the money for the glass however need to make sure other things are fixed first. I dont want to crack a new glass.
Old 02-24-2022, 08:54 AM
  #13689
Money for the glass?
Old 02-24-2022, 09:55 AM
  #13690
BULL
Moderador
BULL's Avatar
Front windshield has always been cracked, it started with a crack by the bottom close to the wiper arm and progressed. In the crash, the hood flew open and added some extra lines as well as a concentrated hit by the driver's side made by the corner of the hood and it seems like this is the spot I'm getting water from.
I did do the straw in the drains and stopped the passenger's side leak. My only leak is by the foot rest. Discovered that garden hose focused only on the windshield gave me drips.
As far as the money went, I set out a crash fixing budget already appointing $300 for a windshield. Since I'm a skeptic I want to make sure the car is aligned and that I feel comfortable prior to installing the glass.
Old 02-24-2022, 01:04 PM
  #13691
So you don't have comprehensive insurance on the car? Just liability?
Old 02-24-2022, 01:11 PM
  #13692
BULL
Moderador
BULL's Avatar
For as long as I can remember in FL you'd need a specific policy that will cover the windshield. I learned this when the glass cracked on my wife's Toyota with full coverage.
The G is staying as liability, as many times as this car has been wrecked getting anything more than that is a waste in my opinion. With anything more than liability they would take the car/give me crap money for it/ask an insane amount to buy it back.
If the history of the car was a bit cleaner I would but, this car has been a Hoe
Old 02-24-2022, 01:40 PM
  #13693
I've been bouncing around trying to look that up. If there were once a specific "windshield" policy, I don't think there is one anymore in Florida, and I think that changed in 2021, if I'm picking up the info correctly. If you have Comprehensive Insurance on top of your Liability policy, then windshields are replaced or repaired for free.
But no comp, no windshield. That's pretty much a given everywhere.
Old 02-24-2022, 02:56 PM
  #13694
BULL
Moderador
BULL's Avatar
I gave up on it years ago, other than the G most of quotes I've gotten for windshields in the past have been pretty affordable, in the end it would be more cost effective to pay for the part than the insurance.
Old 03-05-2022, 09:38 PM
  #13695
mike81
mike81's Avatar
Originally Posted by Mik3G37S
I thought I'd share a few pictures from my Tail of the dragon run this past Wednesday, May 27th when I was over in TN in Smoky Mountains for a week
A moment of happiness after taming the dragon
Few pictures taken by local photographers camping at certain curves who then post the pictures online available for purchase (print, digital download, cd, etc.)
And also was lucky enough to see this 2010 Dodge Viper ACR #17 out of 30 (So I was told). These guys traveled 2 and a half days from Nova Scotia, Canada down to Gatlingburg, TN with the Viper in a specifically designed and built color matching trailer for it, brought it down for a big show consisting of 120 Vipers from across the country and 30 local Vipers as well as other cars. This thing was simply gorgeous..
. Love your tail lights on that G how did you do that?
abrecos (03-13-2022)
Quick Reply: Sedan Chat Thread
