Sedan Chat Thread
In my area (salt belt) this is very common. If it bothers you, I'm sure you can find a good replacement from a scrap yard for a good price.
Moderator in Moderation
I'm sure Canada heavily salts their roads too.
Try to find one on ebay or something from a southern US state... would be cheaper than new, even with shipping and duties.
If there were any in the pick-and-pull near me, I'd grab one for you, but right now there aren't. You *definitely* don't want one of these to snap in a hard rain.
The car is actually from eastern Canada, Ontario, where they salt their roads a lot more heavily than here in Alberta. We use a ton more gravel though, which leads to cracked windshields and rock chips galore. I'll probably sand both of them back in the next month or two and see what I'm dealing with and then if needed grab a set from a junk yard here. Cars from this side of the country rust a lot less than Ontario and further east. Thanks for the offer Mike.
Hope this was no one here: https://jalopnik.com/teen-gets-into-...ool-1847320967
Moderador
Funny how it says driver reversed into the pool but the car is facing towards the picture and the fence behind it looks like was run over by the front end.
Prepare yourselves for the next thread: Car got a bit wet, I have ALL the lights on.
Hello everyone!
I just bought a 2012 g37 sedan with 134k miles on Saturday and just joined this forum. The car is mostly in great shape, but still need some OEM parts. I look forward to learning and meeting most of you
Hi! Why don't you tell us about your new whip in the Newbie forum? (that's the place for intro stories). Meanwhile... welcome aboard, there's a ton of good DIY info here.
Moderador
Dont ever buy a 4WAS car
Toe bolts are too short
Finding a full 4WAS rack is almost impossible without sacrificing a loved one(thank God I found the main body of the rack is the same)
Camber arms I bought are bottomed in currently at 1.5 neg of camber at max inwards
Then the rack was a bit off when I installed it the first time but was compensating with the tie rods (my mistake)
So tried to center the rack and now the steering angle sensor is off a needs to be adjusted
Take the steering wheel off but one of the airbag wires felt like it wanted to drag across the steering wheel and play a prank on me and there went the clock spring.
Had to drive twisted (dog tracking) a couple of days until i got it.
Finalized with a steering angle reset, drive 95% straight but will need another alignment since things could be better.
If I didnt have good friends who help with alignment issues I probably wouldn't have owned the car.
On the way home from driving my kid to work this morning, the "Cruise" text decided to go on in the middle of my dash, and the "Set" command next to it also came on blinking. None of the cruise buttons had any impact on it. I couldn't turn cruise on and I couldn't stop the damn "Set" text from blinking. When I got home, I stopped the car and restarted, and the problem was gone. Using the cruise controls, I even cycled through the EcuTek Maps (although there's only the two), without issue.
I wonder what that was? The only other electronic gremlin I've ever experienced with this car was was the LCD screen getting all twitchy, which is also something that also goes away after restarting the car. That happens maybe a half dozen times a year. But I've never experienced anything weird with the cruise controls before.
DIY Cheapskate/Mod
Rochester (08-02-2021)
Cruise switches at the pedals... I will certainly remember this now, should it become a chronic problem.
Brilliant, Hexotic! Thank you.
Moderador
