Sedan Chat Thread
Old 04-05-2020, 09:07 AM
  #13321
4DRZ
4DRZ's Avatar
Originally Posted by SupraOfDoom
I'm debating getting my car tuned. I wanted to add more mods first but it would kind of be nice to get base line numbers first. Only real performance is CAI/HFC's/Catback. At least next time I'd go back I wouldn't have to pay for the licenses.
Not a bad idea and you would probably make some decent gains with those mods.
Old 04-05-2020, 11:11 AM
  #13322
4DRZ
4DRZ's Avatar
Does anyone have a headlight cleaner they would recommend that is available on Amazon? I have been using a polish to clean up the headlights, but they become hazy again after a few months. Thanks!
Old 04-05-2020, 02:06 PM
  #13323
iCrap
iCrap's Avatar
It's always going be become hazy again unless you coat it with something after with UV protection. Megiuars sells some coating I have used in the past. You can also just spray clear coat on them.
Old 04-05-2020, 03:01 PM
  #13324
RobC7
RobC7's Avatar
^This, clear coating them will be your best long term solution.
Old 04-06-2020, 03:17 PM
  #13325
4DRZ
4DRZ's Avatar
Thanks for the tips about the UV coating and the clearcoat. It looks like there are quite a few kits that have UV protective clearcoat. Any in particular that anyone has had good luck with it lasting or are they all going to be pretty similar? Thanks!
Old 04-06-2020, 04:40 PM
  #13326
iCrap
iCrap's Avatar
I used this one on a few cars. The little bottle of headlight coating worked really well:
Amazon Amazon
On another note, this:
Old 04-08-2020, 08:41 AM
  #13327
doctorg37xs
doctorg37xs's Avatar
Even with no mods, I think it would change the character of the car for the better. Probably more noticeable for non-sport sedans (like mine) that don't pack as much of a punch as the sport sedans. I'm planning on an e-tune this summer with EcuTek, and I've only done FI RHFC's and a Tanabe axle back and don't plan on doing any other engine mods because they don't really seem worth it for the 7AT X sedans. This is a good video to watch:
Old 04-08-2020, 08:51 AM
  #13328
hexotic
DIY Cheapskate/Mod
hexotic's Avatar
Originally Posted by doctorg37xs
Even with no mods, I think it would change the character of the car for the better. Probably more noticeable for non-sport sedans (like mine) that don't pack as much of a punch as the sport sedans. I'm planning on an e-tune this summer with EcuTek, and I've only done FI RHFC's and a Tanabe axle back and don't plan on doing any other engine mods because they don't really seem worth it for the 7AT X sedans. This is a good video to watch: https://www.youtube.com/watch?v=rwbrt30EQcs
Just to clear up a few common misconceptions. There is no difference in power or engine tuning between sport and non-sport sedans. The only car in the VQ37VHR lineup with a differently tuned ecu is the Nismo 370z and IPL g37s. G sport models get a VLSD, slightly different shocks, big brakes, and a few cosmetic quality of life things like more adjustable seats.
Second, AWD sedan benefits from the mods as much as all the other versions. There is more drivetrain loss because of the AWD, so you see lower dyno numbers with the same mods that would give better numbers on a RWD version of the car. You have to take into account gains compared to starting point, not compared to other versions of the car. If anything, the X sedan has the largest exhaust restriction of any G model and benefits from an exhaust system more than any other model. At the moment, I'm putting down 301 wheel on an X sedan with Z1 intakes, Motordyne intake manifold, and top speed exhaust with an UpRev tune.
Old 04-08-2020, 09:05 AM
  #13329
Received 4,646 Likes on 3,476 Posts
That's right, hexotic, no difference.
However, the 6MT came with shorter rear gears than the 7AT, and the 6MT Vert's rear gears were even shorter (although without limited slip, which was odd.) And while that means absolutely nothing with regard to power, it does change whatever perception the driver might have about "punch".
hexotic (04-08-2020)
Old 04-08-2020, 09:09 AM
  #13330
hexotic
DIY Cheapskate/Mod
hexotic's Avatar
Interesting about the 6MT. Not as familiar with it as the autotragic 😂
Old 04-08-2020, 10:04 AM
  #13331
STownSaint
STownSaint's Avatar
Are there any long tube CAI options that are considered to be relatively higher quality than most? Or are they all pretty close to each other?
Mostly thinking of quality in terms of fitment and materials (durability, construction, etc.).
Did some research, are Takeda and Stillen still the top contenders?
Old 04-08-2020, 10:08 AM
  #13332
hexotic
DIY Cheapskate/Mod
hexotic's Avatar
Mostly thinking of quality in terms of figment and materials (durability, construction, etc.).
Admin tuning is up top for both performance and quality. Z1, Stillen and Takeda also have good quality with Z1 leading the pack for performance.
STownSaint (04-08-2020)
Old 04-08-2020, 02:15 PM
  #13333
Mojo_Dp
Mojo_Dp's Avatar
Before you get blasted for this, S never added any more power, unless it was the IPL. S added better handling and brakes on the rwd, and literally only cosmetics for the x ones like mine.
Old 04-11-2020, 10:56 AM
  #13334
SupraOfDoom
SupraOfDoom's Avatar
o.O
Old 04-12-2020, 01:41 PM
  #13335
4DRZ
4DRZ's Avatar
Wow, that's a big gap for premium. The last time I filled up a couple weeks ago in Appleton it was about $1.15 for regular and $1.62 for premium (93 octane) at Woodman's.
Also, why is 93 octane so hard to find in WI now? 91 is everywhere, but 93 for my tune is only at 3 gas stations in the entire area. Is it the same way in Milwaukee or anywhere else in the country?
Quick Reply: Sedan Chat Thread
