Sedan Chat Thread
Old 05-02-2016, 12:02 PM
  #10306
lobuzz311
lobuzz311's Avatar
Originally Posted by ColumbiaSkinny
On a scale of 1-10 what's the difficulty of installing Hotchkis sway bars?
Could i do it by myself or would an extra set hands be much easier?
Difficulty? 2
PITA factor? 4
Like was mentioned, you have to drop (or at least lower) the exhaust to get the rear sway to clear. The front is easy, but you have to drop the front undertray.
I did it alone on jack stands in my garage without issue, so you should be fine. Yes a lift would make it much easier, though, so if you've got access to that I'd use it.
On a scale of 1-10 what's the difficulty of removing the entire center/armrest console?
Difficulty? 1
PITA factor? 3
If you've never taken interior trim apart, it could be a bit disconcerting. It's really not a big deal, though. Just keep track of which screws go where, and follow the guide for the TWM shifter, as it's quite good. The only fiddly part is getting the e-brake up high enough to have the console clear as you're pulling it out. And of course being forceful enough to get things to pop without breaking clips... Getting it back together is actually fairly simple on this car, compared to other interiors I've taken apart.
The following 2 users liked this post by lobuzz311:
ColumbiaSkinny (05-02-2016), Rochester (05-02-2016)
Old 05-02-2016, 12:04 PM
  #10307
4DRZ
4DRZ's Avatar
1- quick and easy.
Old 05-02-2016, 12:09 PM
  #10308
Received 4,727 Likes on 3,532 Posts
Originally Posted by 4DRZ
1- quick and easy.
Figure to be doing this next weekend, in prep for install next week sometime.
So, no problems driving around without the console and everything unplugged?
Old 05-02-2016, 12:37 PM
  #10309
JSolo
Just say no!!!!!
JSolo's Avatar
I installed my bars without removing the exhaust. Rear was a tad tricky as the bar got maneuvered into place but doable. I'm pretty sure I had the stock exhaust on at the time.
Old 05-02-2016, 12:48 PM
  #10310
Received 1,499 Likes on 1,272 Posts
Here's a detailed DIY thread on the install process...
https://www.myg37.com/forums/d-i-y-i...r-install.html
Old 05-02-2016, 01:29 PM
  #10311
ChinkyChoy
ChinkyChoy's Avatar
My exhaust bolts weren't bad getting off when we installed my CBE. I've got around 5k on it now.
The under side has never seen any road salt thankfully and my car only has 21k miles on it. It looked real good up under there.
I haven't looked under the rear end where the sway bar is yet to see what i'll be getting into. I guess i should to get a better idea....
in that case it should be pretty simple and easy for you then just watch out knuckles when turning the wrench lol
Old 05-02-2016, 01:36 PM
  #10312
ColumbiaSkinny
ColumbiaSkinny's Avatar
Yeah i saw that when i typed in 'Hotchkis sway bars' on the google search engine. That's going to be extremely helpful. Thanks for making sure i saw that....
Old 05-02-2016, 01:41 PM
  #10313
ColumbiaSkinny
OMG man, you should have seen me trying to take my grille off. I've got scratches up to my elbows.
I couldn't get the temperature sensor unclipped so the radiator shround would only move so much. Driver side nuts were a beotch to get to. And the bottom clips that i had press up on to release were flattened against a metal plate that was welded to something else. It took me awhile to finally get it. Talk about one aggravated SOB....
Old 05-02-2016, 02:46 PM
  #10314
Lego_Maniac
Lego_Maniac's Avatar
The instructions that should have came with your TWM STS are pretty detailed.
Old 05-02-2016, 07:07 PM
  #10315
Gregor12
Gregor12's Avatar
What are you doing next weekend? lol.....
Going to the Georgia 1/2 mile wanna go fast event! Lol
Old 05-02-2016, 07:19 PM
  #10316
ColumbiaSkinny
Well in that case, go fast!
Old 05-03-2016, 02:53 AM
  #10317
ZahyMatar
ZahyMatar's Avatar
Extra set of hands would definitely help. I've done two installs of Hotchkis, one for myself and helped another forum member out. Used a lift both times. Having an impact is a life saver.
Old 05-03-2016, 04:19 AM
  #10318
Mik3G37S
Mik3G37S's Avatar
Fronts are mad easy, did them myself but well, can't speak for rears as I had my older brother do them for me when I was away running around getting my calipers powdercoated a long time ago, for the rear I imagine an extra pair of hands is necessary to drop down the exhaust a little for sure
Old 05-03-2016, 07:10 AM
  #10319
ColumbiaSkinny
Thanks for the help and suggestions guys, much appreciated.
I know if anything i'll be doing this mod by myself. My buddy who helped me install my CBE and is far more car knowledgeable than i am, may or may not be able to help me this coming weekend. He wants me to wait a couple of weeks to do this at his dads garage where we'll have two of everything we need. But i'm anxious to get this mod done as soon as possible. I get really impatient when i get a mod in my hands that's ready for install. It's go time. I'm real impatient in that way.
But i'll most likely wait just to be on the safe and correct, less frustrating side. Thanks again....
Old 05-03-2016, 07:32 AM
  #10320
Just wait. Self-discipline is good for you.
Northeast Winters are good for learning how to do that.
Quick Reply: Sedan Chat Thread
