Sedan Chat Thread
#946
yeah man... I'm just gonna have to forget about them being on the way for a month or so then just happen to get surprised when they arrive this way I won't get so anxious about them... in the meantime warped ideas you should send me some more pics of the diffuser in the daylight at different angles
#947
A quarter past stripped
Mik3G37S (01-15-2014)
#948
Still on the OEM sways, GFN? I'm kind of surprised by that. As DIY mods go, I think sways would be something you could knock off pretty easy, at a reasonable expense. I had my mechanic do it, but then I get a pass for a whole lot of things now that I'm officially old as dirt. However, I did change the oil & filter on my wife's Honda a couple days ago. And I ripped off her rattling heat shield around the catalytic converter. Not too shabby for an old man.
#950
Because Racecar
Not too shabby on the oil change, I'd be even more impressed if you did it outside!
I keep meaning to switch out the sways, I'm pretty settled on getting the Eibach sways for the front adjustablity and your glowing endorsements. Maybe I've just got some anxiety over getting under the car after the catalytic converter fiasco. It'll get done this year, unless it doesn't.
#952
It's no big deal at all. I change my own oil on both cars; run them up on ramps in the garage. Been using Penzoil Platinum Synthetic, which is only $25 for a 5(ish) quart container at Walmart. I put the old oil in the empty container, and recycle it at AdvancedAuto. And I've been using those K&N oil filters with the 1" nut welded on the bottom, so they come off easy-peasy.
Actually, my superhero moment came when I identified that truly horrible rattle as the upper heat shields on her cat. That took some effort.
But changing oil... meh. This is all you need, man. In fact, this is the very pan I use.
#953
Because Racecar
I'm going to have to do this myself. Up until now, I was still getting my oil changed at the dealership. They offered 6 or so oil changes for free for buying the car. I just got my oil change alert in the car and I've got the oil cooler parts coming in on Friday. I'll just have to hold out until then. I'll be upgrading to a big boy oil filter now that I've got the mishimoto plate. I'll need to do a little more research to figure out exactly what size and model I need to buy. Thanks for the tip about the Penzoil Plat.
#954
I think I've seen that guy before here in Fort Liquordale, hanging out on corners downtown. Oil changes are a pain for me. My car hits ramps before it can roll up them. Gotta jack it up to do anything. Oil chang completed this past weekend and JUST now changed the cabin filter. It was BROWN!
#956
Because Racecar
Welcome to the forum, please use the search function to find more information posted by other members. XD
https://www.myg37.com/forums/d-i-y-i...-box-bulb.html
Here you are, there is a faster way to do it than the guy illustrates in post #1. T
https://www.myg37.com/forums/d-i-y-i...ent-video.html
Cheers!
Rochester (01-15-2014)
#958
Thanks for the video, smart guy. I appreciate that.
OMG, that's a whole lot of screws and panels. You should see how it's done on my wife's car. Takes all of 30 seconds, and zero tools.
#959
No need to completely disassemble the glove compartment box. Just remove the screws and follow the rest of the steps in the DIY on this. Took me 15 minutes and my original filter was horrible. I also drive with the AC full blast and the windows down. Car has 46K so it was time. You'll only need a long Phillips head driver with a ph2 size head. A cordless drill makes it easy..... Make sure you have a magnetic bit though. It could be an issue if you lost a screw.
