Sedan Chat Thread
#5221
Should have not gone Eibach. I have them and I hate the fact that the front is significantly higher than the rear. Talk about uneven drop. Me and John (Rochester) compared our drops and his seems to be more even front and back.
His front is lower than my front, and his rear is a bit higher than my rear. And these are both 6MT RWD sedans we compared.
#5222
There's a lot of confusion on springs with these cars, and I believe it has to do with the differences between RWD and AWD. It seems the Swift springs for the AWD G-Sedan provide an absolutely perfect drop (as measured by fender gap). The RWD setups, not so much.
Repeating my sentiments on the matter, I think about this from time to time, but not so that I lose sleep over it, or get upset. And while I'll likely get CO's sometime in the future, it's equally likely that I'll have my mechanic customize and install those ES bushings in the rear, to lift the rear 1/2". No higher, though... because poke.
I've been meaning to test that out by lifting the entire rear 1/2" with the floor jack. And honestly, if only a half-inch lift eases the rear camber so the rims poke noticeably, then I'm simply not going to do it. I'd rather have a saggy bottom than wheels sticking out like a Flintstone car. Every now and then I look at pics from those few weeks where I had the Vossens without the drop, and it looks ridiculous to me.
Compromises, baby.
#5223
I'm with you in not losing sleep over it. The F/R gap is uneven on the OE springs too.
#5224
well my Eibach on my 7at RWD is perfect stance. Front is lower than rear, I hardly ever hear any complaints about Eibach being lower in the rear than front....you ALMOST always hear somthing with Swift. But doesnt really matter either way about either spring at this point since its already on his car.
#5226
My 09 G37xS (AWD) Lowered on Tanabe - Droopy Bum fix too!(PICS) - G35Driver
Coil mount bushings from Energy Suspension, customized to fit. Pretty clever idea, IMO. In fact, now that we're talking about it, I think I'm going to print out a few pages of that thread, for posterity (no pun).
#5230
$369 for 275/35ZR19 PSS. Seems about right.
#5234
Looks good. Can't tell a difference in how it drive, which is great
Pics below....
Discount Tire Direct, TireRack and Costco were all within $50 for OE sized PSS. Keep your eye out for the $70 prepaid visa they sometimes offer.
That being said, having had both PSS and Potenza S04s, I'd pocket the savings and get the Bridgestones. Unless you're tracking the car, you'll never notice the slight performance advantage of the PSS, and the S04s are better in the wet. Flame suit on
Pics below....
#5235
A 1/4 mile @ a time
[QUOTE="Rochester;3855210"]
GetYourWheels.com: Wheel and Tire Packages|Staggered Wheels|Custom Wheels|Luxury Rims
$369 a tire would be fine with me, except that Discount Tires wants $2,100, yes they want 2 grand... and last time I checked Tire Rack didn't have my sizes (245/30/20 and 285/30/20), I'll have to look again.
