Sedan Chat Thread
#4819
^ i've actually done the same thing with the vinyl window trim wrap. following blnewt's excellent DIY i struggled to do those easier lower pieces with only a couple mistakes before running out of time last weekend. we'll see when i get around to finishing it off, but i kinda like how it looks right now!
#4825
Thank you sir, much appreciated.
#4827
For anyone looking for a rear OEM Spoiler in Obsidian black, found this on ebay for $100 shipped
http://www.ebay.com/itm/2010-10-INFINITI-G37S-SEDAN-OEM-BLACK-TRUNK-SPOILER-LIP-ASSEMBLY-VQ37-3-7L-7062-/271668761114?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f40b8521a&vxp=mtr
#4828
Just because one would install spacers, that doesn't mean there is no longer any function... there is still function depending on how you set them up. a nice flush look won't ruin function at all I'm more of a function over form guy too but if done properly you can achieve a nice stance and yet be functional
#4829
Installed pads today but wasn't able to to get to the fluid. No impression yet as EBC says to drive 200 miles first, then do the bed in procedure. Checked out the rotors and they were smooth as a babies butt so no need for turning. Had I known this I wouldn't have gone through the trouble of taken off the rotors but it is what it is. Now for the fun part. I'm noticing slight vibration at all speeds after putting the rotors back on/new pads. Is it possible that some of the rotors aren't seated perfectly or maybe one of my wheels? I don't see what else could cause the vibration.
#4830
Odd that EBC recommends 200 miles before bedding in the pads?
Did you run some fine grit sandpaper over the rotors or anything?
My guess: you have slight deposits from your old pads, that your new, thicker pads are coming in constant contact with.
