Sedan Chat Thread
#361
Rotating is easy if you have quick access to at tire machine. My girls G has the staggered setup on there and I just swap tires from left to right, and right to left (front and rear respectively). Honestly, if you keep your alignment in spec, you won't eat through tires that easily.
On a side note, looks like I will be going with an FI system from Tony for my 37x. If I'm going to pay ~$800-1000 for an exhaust, might as well get one that will be worth it in the long run. He's offering their new X-pipe at no charge on any system through the end of the year. I don't mind the 6-8 week wait - I'm in no hurry.
#362
Haha - you say you can wait 6 to 8 weeks. Then some time goes by and you think, is this thing going to come? It may take longer, I had to wait about 10 to 12 weeks before I received mine, just to level set with you.
#364
Quick question... where can I can order exhaust gaskets since the ones that I got are not in the best shape and I'm thinking I might have a leak somewhere.
I think I need 6 since the pair between HFCs and "Y-pipe" are good because I put them in there after installing HFCs
#365
Because Racecar
Quick question... where can I can order exhaust gaskets since the ones that I got are not in the best shape and I'm thinking I might have a leak somewhere. I think I need 6 since the pair between HFCs and "Y-pipe" are good because I put them in there after installing HFCs
#369
I love the drive to San Fran though I haven't stopped at the Hearst castle yet.... I have gone further to Napa as well which was a lot of fun though expensive shipping cases of wine home. I take the PCH as far as I can until it cuts into the mountains then follow it through to San Fran. Great drive and scenery. Then head through into Stinson Beach if you're feeling lucky. My favorite drive so far was from Vancouver, BC to San Diego then I hung a left and went to El Paso. Took a couple weeks with the stops at buildings and sights along the way but it was spectacular through the redwoods and so many other places.
I actually do love LA, I've "lived there" for weeks at a time over the past few years. But it's a lot different when the company is paying for everything and all I need to do is work a little and eat!
#370
I went with the middle setting on my Eibachs, after trying real hard to figure out which way to go. Had the same issue for the fronts, because the Eibachs have two settings available in the front.
Went with soft-front, and middle-back, having come to the researched conclusion that you only go aggressive if you're dialing in for the track. Figured once they go on, I wouldn't be changing things, and I haven't.
Of course, the only way to really know is to try different setting combinations and make up your own mind. And if that were something I could accomplish without crawling under the car over and over... meh. I'm a lazy old man.
#371
