Sedan Chat Thread
#3317
Grille painted, overall like the look, but there are a few fitment issues (corners don't fit quite as well as OEM). I'll try to play around with it again but it's in there pretty good for now. Next step is to get & install a QX56 rear Fuji emblem.
Question: Anyone have an idea for how to make a "pedestal" for the emblem? Something similar to how the OEM front emblem is situated
Thanks
Thanks
#3318
Thanks
Thanks
Would also like to know about that pedestal thing, especially since my emblem fell off
I will be removing mine for minor modifications and hopefully install it again in a near future.
#3319
Thanks
Thanks
Mik3G37S (07-21-2014)
#3320
Leatherique - Results
It's the day after I cleaned the leather with the Leatherique, after having conditioned it the night before, and then rubbed in Lexol Conditioner to finish it off. I've wiped all the leather down with a microfiber towel, and truth is I've never been happier with the seats, since even the day I brought it home. The seats look brand new again.
This Leatherique Revitalizer doesn't just treat the leather, it restores it. Man, I'm happy with the results. Those spider-lines are gone from the seat and side bolsters, the dreaded driver's seat bump is gone, everything is that creamy soft color again, and soft to the touch. Wow.
The following 3 users liked this post by Rochester:
#3322
In my area, street parking is most common, then underground garages, then personal garages. Beggars can't be choosers, and it's no big deal w/ the backup cam
And as-is, the grille is too open for me too.
Next step is adding the emblem, then after that, depending how it looks, I'll swap the wire mesh for a heavier ABS mesh
Those stone seats look nice up there, side bolster in my already looks rough, will have to keep that product in mind
#3324
Nice job on the seats John, looks almost as good as Ricardo Mantalbans' Corinthian Leather from the Chrysler Cordoba days
Seriously though, the fact you were able to get rid of the spider cracks on the sides is enough to sell me on the stuff. Going to have to give that a serious look.
STown, like the grill and I'm sure once you get the emblem to cover the center support showing through it will improve the look quite a bit. That really is begging for some showy CAI tubes though, that would really make that grill shine. Paint match looks solid and the fit looks good from the pics, and agree, that would be tough garage to navigate on a regular basis.
Rochester (07-20-2014)
#3325
DIY: TB Coolant Delete - Nissan 370Z Forum
It should help with heat soak, and the parts are probably $10. Considering you live in FL and don't have to worry about your throttle body icing, I don't think there is a downside.
I had this done on my F-Body for 10+ years and never had an issue.
Motordyne use to include this with their intake spacers on the old 3.5 and refer to it as a CCV-- Coolant Control Valve.
Basically, our cars route coolant through the throttle bodies to prevent icing and to help the car warm up. It also ends up routing hot coolant through said throttle bodies, increasing the temp of incoming air. It's not going to add power, but it's going to reduce power loss due to heat soak.
warped ideas (07-21-2014)
#3326
I did a coolant bypass on the TB in my old Maxima, as recommended by NWP Engineering in conjunction with their phenolic intake spacers. IDK if it mattered or not, but it was a simple matter of moving a couple of hoses.
And it made some sense, because the "coolant" was there to actually heat up the TB so it doesn't stick in sub-freezing temps.
#3327
A quarter past stripped
Rochester (07-21-2014)
#3329
I want to do this when I get the time.
#3330
I probably won't be doing this with the G, however. Two TB's and lots of HP already, the mod doesn't really appeal to me (yet).
